Timberwolf Log Splitters?
Discussion in 'Chainsaws and Power Equipment' started by Fanatical1, Mar 13, 2014.
  1. Fanatical1
    Fanatical1
    Does anyone have a Timberwolf splitter or can comment on the one below? I like the large wedge and the Honda motor. They are not cheap however... This one is the TW - P1
    Comments?
    raybonz likes this.
  2. coal reaper
    coal reaper
    Nj
    MY UNCLE HAS ME STORING HIS, ITS A 2 SOMETHING OR ANOTHER. LOG LIFT AND 4-WAY WEDGE. I HAVENT USED IT BUT FOR MAYBE A CORD. IT EATS UP THE 10-20% OF MY ROUNDS THAT I CANNOT EASILY BUST WITH FISKARS. AS FAR AS SPLITTERS GO IT IS AMAZING. RATED AT THE SAME TONNAGE AS OTHERS, BUT I HAVE YET TO STOP IT OR EVEN HAVE IT BOG DOWN IN THE SLIGHTEST. IMPRESIVE MACHINE. BUT AS YOU STATED, YOU PAY FOR IT.
  3. Oliver1655
    Oliver1655
    Central Missouri
    I would definitely get a log lift & out-feed tables to go with it.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I have seen the TW vendors at the fairs in the fall. The demos they do are impressive, they don't just splits the straight grained rounds, they bring in some gnarlies too.
    As coal said, they are quite pricey and if your gonna go with it you may as well go all in with the 4 way and the table too.
  5. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I have used a few of them and in comparison to a 20 ton champion, husky or the like that one is nothing special. It's over priced in my opinion. That's not to say they aren't nice but your really just paying for a name unless you buy the TW-2HD or bigger that's where they shine.
  6. Oliver1655
    Oliver1655
    Central Missouri
    The main advantage is it is a dedicated horizontal. Not normally found at box stores.
    the GOAT likes this.
  7. cnice_37
    cnice_37
    Yes, I've got that one with a 4-way. Plan to build the table.
    Found it used so saved just under a grand (I think it's about $2200 new?)
    Works for me, had I bought new I would have gone Husky from TSC as bang for the buck. I'm in $1400 for mine, pretty sure I could sell it for that today if I wanted.
    It's nice, only problem is small valve leak. I want to add the second hitch as the splits pile up in front of the tongue and trap it.
    Fanatical1 and Pallet Pete like this.
  8. Hedgerow
    Hedgerow
    SW Missouri
    Everything I've seen from TW is well thought out and of good quality, but real expensive.. And there's a lot more to a splitter than just hydraulics.. The little extras are what makes the difference in a truly productive machine.. The TW-1 is really stripped.
    But good quality..
  9. Fanatical1
    Fanatical1
    I have been impressed with them so far, but it's hard to get past the price tags....
  10. MasterMech
    They are one of if not the best in the business (The TWxHD series are awesome units) but if you're looking for a basic dedicated horizontal machine, Iron & Oak and American both build such a critter as well.
    http://www.ironandoak.com/
    http://www.americancls.com/
    Oliver1655, the GOAT and Hedgerow like this.
  11. the GOAT
    the GOAT Banned
    Maine
  12. Fanatical1
    Fanatical1
    I like the Northstar, but shipping is an issue. Wish I had a store closer to me.
    Have not seen the Allwood splitters before. This is nice!
  13. Fanatical1
    Fanatical1
    Found a good deal on a couple of Northstars and need your opinions. The bottom two splitters have the option for a hydraulic log lift for $800 that you need to install yourself.
    What do you guys think?
    1. - 27 ton , GX 160 - $1,550 new
    2.) 32 ton, GX 270 - $2,200 New
    3.) 32 ton GX390 - $2,000 - Slightly used (same as unit above but with an electric start 13 HP GX 390)
    I think this one was barely used, but was sent back for a repair that was fixed.
  14. the GOAT
    the GOAT Banned
    Maine
    Don't get the first one. I have the 30 ton version -- it's well made for the money but I would never buy a horizontal -vertical one again. I'm in the process of converting it to horizontal only so I can add a log lift. I keep the 4 way on it all the time and have yet to fin a log it won't split but the week point is the Allen head bolt that holds the wedge to the rod. It breaks when a gnarly split is stuck on the wedge and you retract the cylinder against the log stripper... It's a 7/16" Allen head bolt (hard to find at local hardware stores)
    I'd get the used one with the bigger engine. I'm not a fan of the log lift that they sell for that splitter though; it seems kind of cheesy. But you could probably convert one from a different manufacturer or make your own for less than nt wants for the lift.
    Of course with the bigger engine a 22 gpm pump would be nice too to speed up cycle times. But everything is a compromise.
  15. the GOAT
    the GOAT Banned
    Maine
  16. Chvymn99
    It just depends on what your aiming for. Do you split big logs? Odd shaped logs? I scrounge most of mine, so that's why I went for a horizontal/vertical splitter. Easier on the back too. From what I can see and pick up most of the engines last as long as they are stored properly and maintained.
    Since you didn't put much on the intro, I thought maybe a few more details on what your looking for and what your trying to achieve. Might help some the more experienced ones help guide and give input. :tree:
    Pallet Pete and the GOAT like this.
  17. the GOAT
    the GOAT Banned
    Maine
    When I bought mine all the wood I got was from scrounges. If I couldn't easily lift it then I left it so I wasn't concerned with a lift. Now all my wood is dropped off for free by a tree service. So I get some bigger logs. I find it a royal pia trying to roll and balance a large logs onto the foot of the splitter on uneven ground. Which is why I want a lift. That and the ergonomics of a h/v splitter are awful in the horizontal mode, tires and the engine are in the way.
    Oliver1655 likes this.
  18. Fanatical1
    Fanatical1
    I have the benifit of having 30 acres of hardwoods. I have always hand split, but usually a a cord or two a year. I have another stove coming and now I'll be around 4 cord/year. Mostly 20" rounds and smaller. A few bigger, but not much. I know with those requirements, almost anything will work, heck I'll be spoiled with anything after using a maul for all these years! I like nice quality stuff and am partial to Honda engines. American made only.
    Pallet Pete and Chvymn99 like this.
  19. the GOAT
    the GOAT Banned
    Maine
    American made honda engines?
  20. Fanatical1
    Fanatical1
    Point taken.... I try to buy as much American built products as possible.
    OhioStihl and the GOAT like this.
