Pelpro, GlowBoy, cheap Charlie - New Accutron IV control panel smoked when powered up!
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Sep 3, 2017.
  1. don2222
    don2222
    Salem NH
    Hello
    You can see the Land on the back of the control panel that burned, it goes to the bottom Triac and also goes to pin 9 on the Molex connector that the wire harness is plugged into! Pin 9 is attached to the red wire which is connected to the stove's Igniter! So it looks like a shorted blown Igniter smoke the board.
    An inline 4 amp fuse may help to prevent this? Any comments?
    A new igniter should be installed before connected another new board!!
    Also recommend the stove be plugged into a good surge protector and the house outlet is 3 prong with the ground going back to the circuit box.
    Pic 1 - Stove
    Pic 2 - Stove Models
    Pic 3 - front of control panel
    Pic 4 - back of control panel
    Pic 5 - burned up land from Bottom Triac to Pin 9
    Pic 6 - shows red wire to pin 9 on the molex connector
    Pic 7 - wire diagram
    Pic 8 - recommended inline fuse holder with 4 amp fast blow glass fuse AGC4 to connect to red wire from control panel to Igniter.
