Easy MS 362CM Muffler Mod
Discussion in 'Chainsaws and Power Equipment' started by lukem, Jan 3, 2015.
  1. lukem
    It is a rainy day here in the Hoosier state so I headed for the shop to clean up. The saw was on the bench so I cleaned it up a bit. Then I decided to pull the muffler cover just for the heck of it to check out the P&C....both of which looked great.
    Then I got to looking and found that it would be super easy to drill an additional hole right next to the stock outlet for a muffler mod. I used a 5/16 bit which will give me room for a little more in the future if needed.
    Pull the muffler cover then pull the rest of the can...6 bolts total.
    Bend back the retaining tabs for the spark screen and remove. Drill a pilot hole then to final size...clean everything up with compressed air and warm water. Reassemble.
    Total time is about 10 minutes and no special tools required (I don't own a dremel) and it keeps the factory spark arrester in place. If it has to be dealer serviced I doubt they would notice.
    Fired it up and it sounds good...not obnoxiously loud. If the rain takes a break I'll put it in some wood.
    If I can do this anyone can.
    Chvymn99, brenndatomu, Hammy and 8 others like this.
  2. prell 73
    prell 73
    ia
    She'll run better
    Hammy and lukem like this.
  3. clemsonfor
    Have more power once it learns the new flow rate
  4. Rains
    Rains
    N.Illinois
    Here is mine, you will notice a difference !!
    MissouriFrontier and clemsonfor like this.
  5. Guntar of Guggenheim
    Guntar of Guggenheim Banned
    Germany
    Whhat does secondary muffler hole due to noise pollution levels?
  6. clemsonfor
    Increase the noise. I bet the OP extra hole will barely be noticeable with ear muffs. You should wear ear muffs anytime you run a saw. Even a stock saw is LOUD!!! You may not think so but they are.
    raybonz likes this.
  7. clemsonfor
    And welcome gun tar.
  8. lukem
    Just took it for a spin. Noticeable difference. Pulls a 20" bar buried in white oak with authority.
    Louder for sure but not bad....I wear foam plugs anyway.
  9. XXL
    XXL
    Ontario, Canada
    Good job! I'm thinking of doing something similar to my MS260 Pro. Did you need to adjust the carburetor any? Other say you need to remove the rev limiters first to get enough of an adjustment once you mod the muffler.
    Chvymn99 likes this.
  10. lukem
    No need to with a mtronic saw.
    Chvymn99, MasterMech and raybonz like this.
  11. XXL
    XXL
    Ontario, Canada
    Missed that and makes sense. Very nice feature.
    T.Jeff Veal likes this.
  12. clemsonfor
    Yea you have to pull the limiters on your 260 to most likely. Maybe not depending upon how wild you modd it
  13. Mastermind
    Mastermind
    Tennessee
    Here's the way we do the MS362. It's pretty simple really.....the deflector is made from 24ga sheet metal. We use a small vice for a brake of sorts. Rivet nuts for the screws.
  14. lukem
    How big is the hole under that deflector?
  15. Mastermind
    Mastermind
    Tennessee
    3/4" or so.
    That is a ported saw though.
    T.Jeff Veal, Drvn4wood and clemsonfor like this.
  16. MasterMech
    Howdy Randy!
    Did you buy a rivnut kit or did you just get the tool and a few rivnuts in the size you need?
  17. Mastermind
    Mastermind
    Tennessee
    I got the tool, and then a few extra adapters for different sizes.
    Finding the thin flanged inserts can be a challenge.....
    T.Jeff Veal and MasterMech like this.
  18. DexterDay
    DexterDay Administrator
    Northeast Oh
    Looking good Lukem... :) That should make a pretty good difference.
    Easy Peasy.. :D
