Chainsaw carrier
Discussion in 'The Wood Pile' started by Sam, Jan 26, 2015.
  1. Sam
    Sam
    Southern Minnesota
    What's everyone using for transporting your chainsaw(s), both to and in the woods? I'm currently using a large rubbermaid tub but I have to take the bars off to get the 044 and the 036 to fit them in there. I like it because I can carry everything together including the gas, oil, and spare bars/chains but it sucks having to take the bar on and off and they don't take very much abuse in the cold. I know I could just sniff around and pick up a couple of the plastic chainsaw shaped ones but I think I'd rather go homemade.
    tuneighty likes this.
  2. crzybowhntr
    crzybowhntr
    WV
    I e the chainsaw shaped ones. I have a powerbox for the 562/359/550/576 and a stihl one for the 038/028. Soon to make one like this....
    Sam likes this.
  3. foragefarmer
    foragefarmer
    Central, Virginia
  4. Sam
    Sam
    Southern Minnesota
    Very cool. So I'm seeing a lot of the scabbard style carriers. Maybe I should mount something like that on the back of my forks, out of the way of the tilt mechanism of course, and then some sort of carrier for the accessories either on the roof or right behind the back window?
  5. JustWood
    JustWood Guest
    Cut a bar hole in the side of your tote with a utility knife .
    Todd 2, Backwoods Savage and Sam like this.
  6. Sam
    Sam
    Southern Minnesota
    I did that to one and it worked alright for the 025. I might do that for the others as well?
  7. KaptJaq
    KaptJaq
    Long Island, NY
    Or, to make sure it is the right size, use the saw to make a plunge cut. ;)
    KaptJaq
  8. gboutdoors
    gboutdoors
    S.E. Massachusetts
    Another scabbard actually two one for the 18" and one for the 14" trim saw.
    Todd 2, Backwoods Savage and Loon like this.
  9. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I'd be skert dat der long bar whuld hit sompin on da way frew da woods....
  10. Woodrat1276
    Woodrat1276
    Ky
    I just put mine in the cab of truck with me or in the wagon secured I have a case but i don't use it often
    Sam likes this.
  11. Backwoods Savage
    No problem carrying everything. There is a metal milk crate in the front right corner that holds gas, oil, sharpener, wedges and/or any miscellaneous items. Now that I have 2 saws, still no problem carrying both in the trailer. Also in there are cant hook, pickeroon, log tongs and chain plus the clevis to use if I need the chain.
    Sometimes we need to plow a little snow to where we want to cut but usually the blade is off. I love to watch that saw operator. I just sit on the atv and sort of try to relax but that can be a problem relaxing..... Now you folks see why sometimes I don't post many pictures. My mind is on other things.
  12. foragefarmer
    foragefarmer
    Central, Virginia
    The bottom of that bar is over 18" off the ground, although it appears closer in the pic. It is what is called an optical illusion.
  13. Ralphie Boy
    Ralphie Boy
    DAT make me feels better. I wuz worried fur yo saw!
    "foragefarmer, post: 252412, member: 24"]The bottom of that bar is over 18" off the ground, although it appears closer in the pic. It is what is called an optical illusion.[/QUOTE]
    Sam likes this.
  14. Ralphie Boy
    Ralphie Boy
    . Now thathat's a saw carrier if I ever saw one!
  15. fuelrod
    fuelrod
    Western Maine
    This storage box / saw carrier has turned out to be one of the best things that I did to that tractor.
    Backwoods Savage, revver6 and Sam like this.
  16. Steven Humes
    Steven Humes
    Holt, Michigan
    My chainsaws are carried on the backs of dead tree souls.
    Just joking in the pickup truck.
    Sam likes this.
