Bixby Maxfire
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by DexterDay, Nov 3, 2013.
  1. DexterDay
    DexterDay Administrator
    Northeast Oh
    Anyone here have any experience with one? I picked one up for $300 and needed a very deep clean. After giving it the once over, cleaning, lubing, and making sure all was right? I fired it up.
    For 10 minutes, all is good. Them after 10 minutes, the initial charge of fuel is spent and it's stays in low? Whether it's on heat level 1-6...??
    I checked The usual suspects.
    The jumper on the stat connection, fusses, other connections, etc.
    Thanks
    savemoney likes this.
  2. slvrblkk
    slvrblkk
    Northampton, PA
  3. jtakeman
    Cool stove dex, You stole that puppy! I always wanted one. You can hook up a laptop to it and program just about anything on it. Should tell you the faults as well.
    Logic cable is pretty cheap too.
    imacman likes this.
  4. DexterDay
    Northeast Oh
    I found the cable (thanks for the tip), but does it need software?
    Slvrblkk, the stove ran for over 45 min, both times and once the initial charge burnt down, it stayed at idle? Regardless of what I did. Thanks for the manual.
  5. jtakeman
    Yes, Need software. I'm not sure where you can download it these days. Used to be available from bixby's site. They also had firmware upgrades too. Bixby quite making the stoves IIRC. I'll se if I can post some links?
    http://www.bixbyenergystoves.com/
    Link doesn't seem to work anymore? :mad:
  6. imacman
    imacman
    Denver, NC
  7. imacman
    imacman
    Denver, NC
  8. krooser
    krooser
    Waupaca, WI
    The inventor of the Bixby stove? :campfire:
    will711, imacman, gbreda and 5 others like this.
  9. Rona
    Rona
    southwestern Minn
    Your description of the problem tells me the thermo sensor wire either fell off the board or is not connected good enough. It is supposed to sense exh temp change and tell the board you have heat then it will keep running. But if its not connected to the board it will start and stop after about 10 minutes. Look at the large board upper right corner there should be a white connection and the stiff brown wire with a flag is supposed to be connected there. Wiggle it and it will fall off or move the stove and it will come off.
    There is a fitting on the smaller board that will fit but don't connect it there as it is wrong.
    kappel15, DexterDay and wildwest like this.
  10. Rona
    Rona
    southwestern Minn
    I have the various software 202-206-270-2.71-2.73, Manual for Bixcheck and dealers manual for 115, and the UBB and 120
  11. alexismyboy
    alexismyboy
    Maryland
  12. alexismyboy
    alexismyboy
    Maryland
    Hello Rona,
    I am having problems with my Maxfire 115. it fires up from a cold start then after reaching what would be operating temperature it cycles and does an ash dump and then repeats the prccess....as if it is not seeing that it is fire engaged.
    May I ask you to assist me.
    Can I secure a copy of the software (I have a Maxfire 115), manual for Bixchek, and the manaul for the 115?
    Please let me know.
    Thank you very much.
    George (Alexismyboy).
    DexterDay and jtakeman like this.
  13. jtakeman
    Welcome aboard George!
    Paging Rona
    alexismyboy, DexterDay and imacman like this.
  14. imacman
    imacman
    Denver, NC
    X2
  15. DexterDay
    Northeast Oh
    Welcome to FHC George!!
    Hope you get the info you are looking for. :)
    jtakeman and alexismyboy like this.
  16. alexismyboy
    alexismyboy
    Maryland
    Rona -
    Hope to hear from you soon!
    George
