Woodstock Fireview Rebuild
Discussion in 'Modern EPA Stoves and Fireplaces' started by Todd, Jan 5, 2025 at 3:50 PM.
  1. Todd
    Todd
    NW WIS
    Found this on Marketplace, paid $400. Was never fired and inside a barn for a long time.
    it’s rusty but no warpage. Some stones are deteriorating and gaskets are toast.
    Years ago I tore down a Keystone so I’m going to tackle this one and either sell it or install in my cabin.
  2. brenndatomu
    Nice...is this the one you said the guy was hung up on getting $1500, or some such nonsense?
    Backwoods Savage, wildwest and Todd like this.
  3. Todd
    Todd
    NW WIS
    No that was a different guy that was selling an old Classic.
  4. Todd
    Todd
    NW WIS
    Started taking her apart. Bolts are coming out easily. Removed the cat scoop and bypass housing. They’re all in decent shape. The top frame that holds the top stones is going to have to be replaced. I may just replace all the outside stones, they don’t look so good.
  5. brenndatomu
    What specifically do you see there that looks bad?
    Are stones expensive?
  6. Todd
    Todd
    NW WIS
    I can take my figure nail and scrape it off. It’s kind a wavy in spots and flaking off. I don’t know how much the replacement stones are, maybe I’ll find out tomorrow from Woodstock.
  7. brenndatomu
    Isn't soapstone soft like that anyways?
    Wonder if it can be refinished in any way?
    Backwoods Savage, Todd and wildwest like this.
  8. Brad M
    Brad M
    Pleasant Hope MO
    I rebuilt a Fireview 10-12 yr ago and I rubbed the stones down with some 0000 steel wool. That cleans them up nicely. You might give that a shot before deciding on replacing them.
    wildwest, BCB and brenndatomu like this.
  9. Todd
    Todd
    NW WIS
    Thanks I tried that but most are beyond steel wool. It’s almost like it’s wet chalky flakey deteriorating. I shouldn’t be able to dig my finger nail into it and scape it off. I am working with Woodstock to get a list of what I need.
    I just about have her stripped down. Having trouble removing the four rods that run up and down the corners that hold the stones and frames together.
    wildwest and brenndatomu like this.
  10. brenndatomu
    Drill the heads off?
    wildwest likes this.
  11. Todd
    Todd
    NW WIS
    It’s a threaded rod with nut on the bottom of the stove on all four corners. When I put a wrench on them I can turn them about a quarter turn and they want to spring back. Not sure why this is but I’m waiting on a reply from WS to see if I can just cut them off and replace. Didn’t want to risk breaking something if I really tork it.
    wildwest, Eckie and brenndatomu like this.
  12. Todd
    Todd
    NW WIS
    Well I got two of those threaded rods loose and snapped the other two off. May as well replace all four.
    woodstock is getting my order together. They said the stones are anywhere from $15-50. I don’t think that’s too bad at all.
  13. brenndatomu
    Probably costs that much to ship too!
  14. Todd
    Todd
    NW WIS
    Ha yeah I forgot about that.
  15. Todd
    Todd
    NW WIS
    Had to lay her on her down to get access to those tie rods so I went ahead and wire wheeled and painted the bottom.
  16. JD Guy
    JD Guy
    Upstate SC
    Nice work and you’ll have her looking and heating great again!
  17. BCB
    BCB
    Ocean Co, NJ
    Nice. I rebuilt a 201 model Fireview 8 years ago and am sitting by it as I type this. Great stoves! Woodstock does a great job w keeping parts available and they're very helpful w questions.
    Fairview fireplace install question
    wildwest, brenndatomu and Todd like this.
  18. Todd
    Todd
    NW WIS
    Totally taken apart now. I dropped the flue collar assembly and broke it so there’s another cost. Gonna start working on the iron while I wait for parts.
  19. Todd
    Todd
    NW WIS
    Looks so much better with some fresh paint on that iron!
    Pyromaniac, Dok440, BCB and 2 others like this.
