Woodsplitter modifications thread
Discussion in 'Chainsaws and Power Equipment' started by Lennyzx11, Dec 22, 2021.
  1. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    Starting a new thread discussing changes made to our splitters to make them better for the individual using them.
    Slocum, Chvymn99, Screwloose and 6 others like this.
  2. Lennyzx11
    Lennyzx11
    So my Timberwolf TWP1 has been a great splitter but has some things I didn’t like.
    First is too low. Though I had ran it up on ramps and that worked, it was also a bit of work to move it from place to place around my land.
    So first thing is raising it. I went to my scrap yard and found a piece of square tube and started making a spacer block.
    More to come.
    Slocum, Chvymn99, Screwloose and 16 others like this.
  3. triptester
    triptester
    S.E.Wisc.
    Didier modification. 12 volt electric winch operates the log lift.
  4. sirbuildalot
    sirbuildalot
    Mass
    I have several videos on improvements I've made to my SuperSplit.
  5. Chris F
    Chris F
    Micksburg, Ontario
    Other than upgrading to a Honda engine, I installed a jack at the front with a wheel to make it easier to move around in the garage. That sucker is heavy!
    Or maybe I'm just getting older.
    Slocum, walt, Chvymn99 and 10 others like this.
  6. T.Jeff Veal
    Your videos are cool, brother
  7. Lennyzx11
    Lennyzx11
    I hear you. That’s next on the list. I needed to get the rear height set then put the front jack on like you describe.
    Chvymn99, Screwloose, Dok440 and 6 others like this.
  8. T.Jeff Veal
    We are lucky to have 2 splitters. The vertical is about 22 yrs old. We built a platform from 1 1/2" pipe and 2" angle iron. Really helps with big rounds. Slides easier onto the splitter foot. 0720202018.jpg
    The TSC 30 ton we leave horizontal, it's 3x faster. We have done several improvements to it.
    Added 2 - 2×10×8 boards for ramps and a center support on the ramps 0408201035.jpg
    Then we added some flat bar to the foot, so the wedge will go through the round, really helps with stringy woods 1120211021b.jpg
    Slocum, Chvymn99, WinonaRail and 9 others like this.
  9. Backwoods Savage
    Right on. That is usually the first thing one needs to do.
    Slocum, Chvymn99, WinonaRail and 5 others like this.
  10. Lennyzx11
    Lennyzx11
    Good one Jeff. I seem to spend countless hours bending over and picking up the hatchet or the pickaroon that vibrates off and falls from where I laid them.
    And I plan on incorporating a cupholder!
  11. sirbuildalot
    sirbuildalot
    Mass
    Thank you sir. Appreciate it.
  12. Chris F
    Chris F
    Micksburg, Ontario
    That pipe ploatform is the next mod for me.
  13. Erik B
    Erik B
    Western Wisconsin
    I made a slip on piece to allow the wedge to go completely thru a stringy piece of wood. I only have one splitter and this one just lifts off easily if I have to run the splitter vertically.
  14. triptester
    triptester
    S.E.Wisc.
    Here is a splitter a friend wanted totally reconfigured. Started out as a 1 year old Dirty Hands splitter IMG_1231.JPG
    After mods. Table style with full suspension ,log lift, and duel fuel, gas or propane. IMG_1231.JPG IMG_1236.JPG IMG_1237.JPG
  15. Eric VW
    triptester - the work you did on that layout reminds me walt ’s standing vertical splitter.
    :yes:
    Dual fuel is sweet!:thumbs:
    metalcuttr, Chvymn99, walt and 5 others like this.
  16. Horkn
    metalcuttr, Chvymn99, walt and 4 others like this.
  17. triptester
    triptester
    S.E.Wisc.
    The log lift is a simple cable and pulley from wedge to log cradle.
    On the red splitter the cylinder is in the operating position.
    On the black splitter the cylinder is in the travel position.
    splitter robin engine 002 (Small) (2).jpg Beefie splitter 016.jpg Beefie splitter 020.jpg
  18. WinonaRail
    WinonaRail
    Indiana, US
    I installed the wheeled jack shortly after I got mine. Love the seat for vertical splitting!
    metalcuttr, Chvymn99, walt and 2 others like this.
  19. Chris F
    Chris F
    Micksburg, Ontario
    Backwoods Savage has the patent on the milk crate seat and that's where I got the idea from.
    But he's a very generous man and will let anyone copy it without financial gain.
    Just giving credit where credit is due :yes:
  20. Nitrover
    Nitrover
    Lake Erie
    Just a simple stroke limiter I did recently, every little bit helps
