Wood Stove Thermometers
Discussion in 'Modern EPA Stoves and Fireplaces' started by Huntindog1, Sep 5, 2014.
  1. Huntindog1
    Huntindog1
    South Central Indiana
    I am thinking about trying to find the best Thermometer as mine are getting old.
    I think Condars are the best. So I think I will cut to the chase and just get me a Condar Wood Stove Thermometer. I have a infrared one but I like having the Condar on the stove top and one on the stovepipe.
    I use the infra red one as a double check. Sanity Check.
    I am ready Old Man winter come get me.
    I will say I bought cheaper SBI thermometers last time and didnt like them. So I went back to my old ones
    which are condars.
    So many Condars now I got to figure out which one is the best.
    Then find a sale on them. :popcorn:
    PS. We need a smiley of a stove thermometer pegged to super hot reading. Maybe flames coming out the top.
  2. Huntindog1
    Huntindog1
    Here is my infrared device. Best part about this one is its a good price and still measures over 1000 deg F. Most ones this price range only measures around 700 deg F.
    http://www.amazon.com/Neiko-Infrared-Laser-Thermometer-Non-Contact/dp/B005K1N7F4/ref=sr_1_77?ie=UTF8&qid=1409928637&sr=8-77&keywords=infrared thermometer
    Here is a good review on it.
    24 of 25 people found the following review helpful
    Great deal with many features not normally found within this price range.
    By yeri63on July 18, 2012
    Verified Purchase
    Now I must admit, I spent quite a few hours investigating the many models out there, debating long and hard which one to select. This model initially caught my eye, because of it's clean look and color scheme, easily fitting within a kitchen environment, small workshop or lab.
    I wasn't sold completely though, since I could not find the exact features this model provided. As a result, I strongly considered some of the other brands, but wasn't crazy about the red or yellow and black color schemes available, screaming high tech test equipment. Despite my misgivings, I purchased it anyways, with the intent of seeking a refund if it didn't meet expectations. Thankfully, I was pleasantly surprised.
    During my research of IR Thermometers I found a number of features that kept popping up, and so concluded that while not absolutely necessary, they could definitely increase it's functionality, allowing me use the thermometer in more scenarios. I ended up creating the following to help narrow down my choices.
    List of Parameters for the Ideal IR Thermometer
    - Powered by AA or AAA cells, as opposed to a 9 volt battery. The AA or AAA cells would provide more current, giving many more hours operating before having to replace the batteries.
    - Adjustable Emissivity from 0.1 to 1.00. Allow the unit be used for measuring temperatures of more materials accurately than those units fixed at 0.95 or 9.97.
    - Laser pointer to indicate where the temperature scan is taking place. Ideally, activate automatically every time a temperature scan is taking place.
    - D:S ratio of at least 12:1. This refers to the Distance to Size ratio, where the size of the circle being measured gets larger the farther away from the sensor within the unit. Higher numbers are better. In this case, a D:S = 12:1 means that at 12cm, the size of the circle is only 1cm.
    - Max, Min, Avg, and Diff readings. Even though the unit is great for displaying surface temperatures, it would be nice to be able to multiple readings during the same session and determine the Maximum, Minimum, Average or Difference between Max and Min. This saves having to calculate this manually, or hope that the last temperature scan was one of these values by happenstance.
    - Hot ALarm and Cold ALarm settings. With these, the unit can inform you when either limit has been met or exceeded using an audible beep and/or indication on the display.
    The Neiko IR Laser Aim Thermometer Gun hits pretty close to these ideal parameters. Those areas where it's falls short, and the reason for one less star in my rating include the following...
    - Powered by a standard 9 volt battery. This means the run time is considerably shorter than the non 9 volt battery models. The workaround would be building a small 9 volt battery eliminator running off of a couple of AAA or AA batteries. The resulting circuit would have to be no bigger than a 9 volt battery to still fit within the handle.
    - The laser pointer requires a button press to activate. Fortunately, the laser remains on for the current power session.
    - D:S = 10:1. The Distance to Size ratio is less than ideal, but still pretty good. At a distance of 10cm, the size of the area being scanned is only 1cm.
    - No Differential temperature readings. Those would have to be calculated manually if required.
    - The Hot and Cold ALarms do not generate an audible alarm, but do show an indication on the LCD screen that a limit has been met or exceeded.
    Despite these shortcomings, this still is a great IR Thermometer, well surpassing the feature set of other brands costing up to 4 times more!
    To same you some valuable time if you find yourself in the same shoes comparison shopping, here's the Quick Start Instructions (describing the feature set) and Specifications from the Instruction Manual which ships with the unit.
    1. Press battery door clip, and install the battery. Pull the trigger, and the LCD will display the reading and battery icon. Release the trigger and the reading will hold for 7 seconds.
    2. Locating a hot spot, aim the thermometer outside the area of interest, then scan across with up and down motions until you locate the hot spot (turn on the laser to assist with accurate measuring).
    3. Buttons/Switches
    a) Trigger switch - Press to turn on, and then display the test result. It will hold data 7 seconds automatically after releasing the trigger switch, and turn off automatically after 10 seconds with no activity.
    b) Laser Pointer button - Press it to turn on the laser pointer. Press again to turn off.
    c) Back light / Up button - In "Alarm Temperature" and "Setting Emissivity" mode, use to raise the value up one digit. Otherwise, use to turn on the back light while the trigger switch is held. Press again to turn off.
    d) Mode button - Press MODE button to cycle options (MAX, AVG, MIN, HAL, LAL modes).
    MAX - Measure maximum temperature within the current data.
    MIN - Measure minimum temperature within the current data.
    AVG - Calculate the average of all measured data.
    HAL - Alarm of high temperature. While in HAL mode, press the UP or DOWN buttons to set the alarm temp. The LCD display will display an "H" when this alarm temperature has been exceeded.
    LAL - Alarm of low temperature. While in LAL mode, press the UP or DOWN buttons to set the alarm temp. The LCD display will display an "L" when this alarm temperature has been exceeded.
    e) T/DN button - In "Alarm Temperature" and "Setting Emissivity" mode, used to adjust the value down. Otherwise, used to select C or F temperature scale.
    f) SET button - Press to set emissivity. Then press "UP" or "DN" buttons to adjust from 0.1 to 1.0. Press the SET button again to exit this mode.
    Specifications
    Temperature range: -30 to 550C (-22 to 1022F)
    Accuracy: +/- 3C or +/-3% of reading -30 to 0C (-22 to 32F)
    +/- 2C or +/-2% of reading 0 to 100C (32 to 212F)
    +/- 3C or +/-3% of reading > 100C (212F)
    Display spot size: 10:1
    Repeatability: 1% of reading or +/- 1C
    Response Time: 500ms
    Spectral Response: 8-14um
    Emissivity: 0.1 - 1.0 adjustable
    Relative Humidity: 10-95% RH non-condensing
    Operating Temperature: 0 to 60C (32 to 140F)
    Storage Temperature: -20 to 60C (-4 to 140F) without battery
    Power Supply: 9V 6F22 battery
    Battery Life: 12 hours
    Product Size: 165 x 80 x 41mm
    Product Weight: 155g (without battery)
    wildwest likes this.
  3. Huntindog1
    Huntindog1
  4. Backwoods Savage
    Wow! Amazon has some good prices on those.
    I'm like you with the condar thermometers and also checking them from time to time with the IR.
  5. HDRock
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    I use condar here, works well on the stovepipe for me
    This will also be a testing kind of year with a new stove
    on the hearth.
    BrianK, papadave and wildwest like this.
  7. Locust Post
  8. wildwest
    Wyoming high plains
    Is it wise to use a magnetic thermometer on a pellet stove pipe? We had one on our old stove, and its since broken. thanks
  9. DexterDay
    DexterDay Administrator
    Northeast Oh
    I have a Tel-Tru and love it. It's pricey, but it is super accurate and also has a high limit needle. So you know how hot each load was at its peak temp. Ideal for people who are wondering if they over fire when they leave for work or after they retire for the night.
    concretegrazer, HDRock and wildwest like this.
  10. wildwest
    Wyoming high plains
    Sorry for all the fuss, I am on tel tru and I cannot identify what will work for a pellet stove. Any key words you can offer?
  11. HDRock
  12. DexterDay
    Northeast Oh
    For a pellet stove, you don't need one. If you wanted something to identify the heat difference of different pellet brands? Then you would want a cheaper K type Thermocouple to measure the output air temps. I have a small Cole Palmer Thermocouple I use to measure the air temps. Works great.
    A magnetic thermo isn't conducive for a Pellet stove. Very hard to overfire. Lots of engineering and R&D has gone into them and their individual heat levels. The unit you are buying can be ran on a high heat level for extended periods of time. By extended, I mean days..
  13. My IS heats my home
    My IS heats my home
    Albany, NH
  14. Locust Post
    I almost put that in my post IS, I'm guessing they are made by someone else because as far as I know Lehmans does not manufacture their own products although they have a lot of nice stuff.
  15. Todd
    Todd
    NW WIS
    HDRock likes this.
  16. Woody Stover
    Woody Stover
    Southern IN
    When I saw that one, I thought 'Re-badged Condar.'
  17. Todd
    Todd
    NW WIS
    I think I jinxed myself, my probe seems to be messed up, its reading all over the place. I wiggle the wire and it jumps up and down hundreds of degrees.
  18. My IS heats my home
    My IS heats my home
    Albany, NH
    How old is your probe Todd? With what your telling us, it sounds like it's not in good shape. Have you burned with it yet this year?
    DexterDay likes this.
  19. DexterDay
    Northeast Oh
    Is there any heavy kinks /bends in the line? If the thermocouple has a broken wire, before the end, it will read all wacky.
    Do you have any hard turns/bends (90° and over) in your system?;
  20. Todd
    Todd
    NW WIS
    No bends or kinks. I ran it all of last season with no problems. I'll probably just go back to monitoring flue and stove top temps and use the thermocouple with different probe for beer brewing.
