Wood stove run by a thermostat! What?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sconnie Burner, Sep 10, 2015.
  1. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    Just cruising through the wood stove manufactures sites seeing whats new and getting ideas and options for a future home purchase, I came across the Quadra-fire adventure series that are run by a wall thermostat! I currently am using the 3100 steptop in my buddies house that I'm renting from him and its a great little stove. So I'm intrigued and guessing this is pellet stove like technology being applied to a wood stove.
    With the III (3) series boasting a 4.0 cu ft firebox accepting 22" recommended splits, able to heat 3,500+ sq ft, and claims of 40 hr burns (we all know 12-14 would be most realistic), it even runs on a 6" flue! Its definitely an interesting set up and will be interesting to see and hear how it actually performs.
    http://www.quadrafire.com/Products/Adventure-III-Wood-Stove.aspx
    Doug, milleo, raybonz and 3 others like this.
  2. Babaganoosh
    Babaganoosh
    Jersey Shore
    We are going to be seeing more and more stoves or systems like this in the next few years. I've already got some stuff in my house set up for home automation.
    The one big issue is what happens in a power failure?
  3. wildwest
    Wyoming high plains
    I understand how a thermostat works on a pellet stove, but wood stove? Wow!
  4. brenndatomu
    Meh, this thermostat "technology" has been on wood furnaces for years :whistle:
    But it will be interesting to see what the new regs bring about in wood heaters
  5. wildwest
    Wyoming high plains
    What does it do, control air intake?
    Stinny likes this.
  6. brenndatomu
    Yup
    Stinny and wildwest like this.
  7. bushpilot
    bushpilot
    Eastern Washington
    I am sure it will never be approved for Washington State. No OWB has yet been approved.
    Greg
  8. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    It sounds like it will run on 6 D cell batteries for up to 30 days. Just the control board and air controls of course, Not the blower fan.
  9. Norky
    Norky
    Starting at $3,499
    • Maintains the temperature of your room with a programmable thermostat
    • Automatically adjusts your stove, eliminating all manual air controls
    • Tells you when to add more wood
    • Allows you to load the wood, light the fire and walk away
    What could go wrong?
    Gark, papadave, gmule and 1 other person like this.
  10. brenndatomu
    I don't know about OWBs but I'm betting somebody will get there on a indoor furnace...ever hear of Kuuma Vaporfire? http://r.search.yahoo.com/_ylt=AwrBT8dryPJVDWUAfBRXNyoA;_ylu=X3oDMTByOHZyb21tBGNvbG8DYmYxBHBvcwMxBHZ0aWQDBHNlYwNzcg--/RV=2/RE=1442003180/RO=10/RU=http://lamppakuuma.com//RK=0/RS=woHtR2ds5fGfcJpxcCRfdB9eR_s-
    I bet they could make the cut if they ever decided to spend the money to try
  11. Babaganoosh
    Babaganoosh
    Jersey Shore
    That stove sounds very similar to a wife or gf during winter! Hahah
    swags, Horkn, cnice_37 and 1 other person like this.
  12. mike holton
    mike holton
    Old Dominion
    furnaces were not regulated per se the same as freestanding stoves or inserts with the old Phase 2, now the Step 2 regs have closed the "furnace loophole" and with that in mind I suspect you will see "certified" furnaces out in the next year or two. we are working up to do one as well as our current furnace was in that loophole as virtually very other out there was.
  13. Stinny
    Ashley woodstoves had a mechanical thermostat on the front of the unit that controlled the air intake. A simple coil spring would expand and contract from the stove's heat. We had an Ashley just like this one in our home in the 70s & 80s. It worked perfectly. I wish I had a control like it on the front of our Liberty.
    CleanFire, milleo, papadave and 3 others like this.
  14. FastDonzi
    FastDonzi
    East TN
    Doesn't the Blaze King Princess use Coil Spring setup for their "Air Governing" I haven't seen it, but from reading that seems like it...
  15. Innovator
    Innovator
    Kitchener, Ontario
    Firing rate can only be controlled via primary air supply. Secondary and tertiary air supply completes the combustion of fuel vapours (like any EPA type stove). Primary and secondary air supplies must always be in proportion to each other. This is nothing new. A properly programmed PID type temperature controller is key to keeping a stable room temperature. Too low stove temperature indicates need for more fuel (wood). All this is very good, but at what price?
    wildwest likes this.
  16. Highbeam
    Highbeam
    Yes. The bk stat is driven by stove temperature vs room temperature though.
    The quad stat will call for heat based on room temp and open the primary air. When room temp is at set point, the primary will close a bit but we all know that a noncat can't be run very low before it pollutes so I propose this product will suck. The stove will never be less than a huge 4c.f. stove at 400 degrees. The marketing suggests that the room temperature will be regulated but with a stat that can only choose between hot and really hot, the operator will be doing the control.
    Nice big stove on a 6" flue.
    rdust likes this.
  17. Innovator
    Innovator
    Kitchener, Ontario
    You are most likely right about the stove. It can only be turned down to a minimum where combustion is still good. This may still be too much heat for a room. The only really good solution is to have a stove that transfers most heat to a large heat sink (water tank). Heat-Booster has developed water heating systems for wood stoves. Operate stove normally during the day, and use stored heat during the night. Stove can be operated properly this way. Medium to high burning rates result in clean burns even with older stoves.
  18. wildwest
    Wyoming high plains
    No such thing!
    Is that what the water tanks are for in a 1910 cook stove? Or something else?
    Stinny likes this.
  19. DexterDay
    DexterDay Administrator
    Northeast Oh
    Looks like there is a convection blower also? I wonder if the thermostat controls the blower? That would help in heating a room up quicker and if it shut down, would aid in lower room temp.
    This is not new technology for pellet stoves. Also, that looks to be the same controller housing that Quad uses for the Mt. Vernon AE pellet stove.
  20. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    I did read it will run the blower as well. The max speed has to be set manually but it supposedly runs it at variable speeds below that set point when there is a call for heat. Not sure if it just turns it on and off or actually can change the speed of the fan.
    DexterDay likes this.
