Wood splitting cleanup
Discussion in 'The Wood Pile' started by boettg33, Nov 17, 2014.
  1. boettg33
    boettg33
    Wakefield, RI
    All
    What do you do with the park and scraps that are produced from wood splitting? I plan to use it, but need some suggestions for drying and storing the smaller bark/wood splinters from the wood splitter.
    Thanks in advanced
    Jason from RI.
  2. NYCountry
    NYCountry
    Mohegan Lake NY
    I usually use it for the pit. I use crates and stack them on top of each other and cover it with a piece of plywood. I usually stack 5 crates high . I put them on pallets to keep them off the ground
  3. Shawn Curry
    Shawn Curry
    Western NY
    I save the splitting trash for kindling. I don't do anything with the bark though, except dump it in the woods.
    splitoak, Gark, Drvn4wood and 4 others like this.
  4. coal reaper
    coal reaper
    Nj
    dont use much kindling so i just burn the junk in a pit while i am spliting and stacking to keep the bugs at bay. entertains my boy too so wifey gets a break.
    splitoak, Gark, basod and 5 others like this.
  5. thistle
    thistle
    Polk/Guthrie Counties,IA
    I still split all my wood manually,all those slivers etc are saved for kindling.Depending on species bark pieces are either burned or broken up then dumped over a couple low spots in processing area.Nice to walk on,especially when mixed with shavings/noodles,better than having mud.Cleanest pieces of Hickory bark I keep a few pounds in a sack for use in future syrup making.
    splitoak, basod, Todd 2 and 5 others like this.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Kindling.... And the small stuff i use for starting my honey bee smoker :)
  7. bigbarf48
    bigbarf48
    Stone Mountain, GA
    Bigger chunks and slivers, as well as large pieces of bark, just get tossed in the burn pit
    Smaller stuff and noodles I just leave on the ground. Like thistle said, it's better than mud. Kinda like free mulch :thumbs:
    fuelrod and HoneyFuzz like this.
  8. yooperdave
    At the cottage, the scrap goes right to the burn pit. As I'm feeling all the heat from the bark and splinters, I'm thinking how nice it would be for the OWB at the house!
    HoneyFuzz likes this.
  9. GOT WOOD
    GOT WOOD
    Dutchess County, NY
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    Good question boettg33 . Welcome to FHC as well!
    I'm sure everybody has their own thing when it comes to the debris
    from using the splitter/chainsaw. I keep the larger pieces and use them as kindling
    the smaller stuff, including bark, I put aside for the firepit.
    Clean chainsaw shavings and chips I use for making firestarters.
  11. boettg33
    boettg33
    Wakefield, RI
    Maybe I'm nuts, but everything with the exception of the sawdust goes into my wood stove. Only problem I've not come up with a solution is storing the scraps properly and getting them thoroughly dried out. I tried using an aluminum garage pail in the past. The problem there was the condensation buildup.
    Shawn Curry and Backwoods Savage like this.
  12. My IS heats my home
    My IS heats my home
    Albany, NH
    If you are using the scraps for the woodstove thats ok. Your problem is getting the green scraps dry before tossing them in. A bucket will not get the contents dry throughout. I'd almost have to say spreading them out over an open area to dry it would work better.
  13. Uncle Augie
    Uncle Augie Banned
    North Of Canada
    Try getting a package of the large paper lawn debris bags. I have a couple that I store in the garage. All small twigs / splitter debris from around my small yard get put there. By the fall they are dry enough for kindling. Bark goes in the compost pile. I keep my compost pile active with frequently turnings, water, and lots of food. Usually takes 2-3 months to turn all of that into quality compost for the garden.
  14. cnice_37
    cnice_37
    I have used milk crates and then leave them on the driveway for a week during a hot summer week. Now I just stack the decent sized ones in the stacks with the rest of the wood and grab the kindling when I hit it in the stacks. Any chunks of cooking wood get stored in a separate pile.
    I have about 20 boxes of kindling in my basement stored in diaper boxes. Once those are gone, I am just using the stuff in the stacks, easier for me and just as dry. Then I will just put them in a bin to bring in the house when its reloading time.
  15. boettg33
    boettg33
    Wakefield, RI
    I was thinking about building a medium size storage box vented on the sides and bottom. This might be overkill. I like having wood projects.
  16. bogydave
    I smoke myself away from the splitter & keep the bugs away :)
    more steam than smoke.
    I just start a fire, the birch bark burns good & hot & eventually the wet wood dries out & burns.
    Rake the area now & then to keep it clean enough to work comfortably.
    + the fire gives me a place to warm up when needed.
  17. bigbarf48
    bigbarf48
    Stone Mountain, GA
    I always have a fire going while splitting as well Dave. I just pile up all my chunks/uglies/shorties/scraps and grab from the outside. Once I have the fire going with dry splits, the chunks from the outside of the pile are dry enough to catch and burn alright
  18. bogydave
    Yea
    I had to thru some dry wood on there from the fire-pit stuff,
    when boiling water out of the wood, it's hard to keep it burning.
    Wind shifted, the smoke & steam ran me away from the splitter.
    When I have the same type stuff in the house wood box.
    I goes in the stove, good & dry by then, it burns hot & fast
    bigbarf48 likes this.
  19. Backwoods Savage
    Welcome to the forum Jason.
    When done splitting in the spring, I simply leave the trash. Then my wife gets tired of looking at it and picks it up to use as kindling. In fact, just a couple days ago I found another milk crate full in the barn. Yes, milk crates work well for this.
    Shawn Curry and basod like this.
  20. Paula
    Paula
    UK
    Kindling here too :)
