Wood splitter control valves
Discussion in 'Chainsaws and Power Equipment' started by rusty ranger 44, Mar 17, 2021.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    I want to upgrade my wood splitter with the addition of a log lift. The only hold back is which control valve to use as there is manly to choose from. My current splitter has one control valve configuration to operate the horizontal ram. To those who have built their own splitters, does anyone have a source of hydraulic schematic required to operate the ram and the log lift at the same time. Any suggestions would be helpful.
    Stlshrk likes this.
  2. Nixon
    Nixon
    West Sunbury,Pa .
    Try this place ... Surplus Center look at the valves you think may suit your set up . Call them ,and ask for their guidance on the subject . Also , be careful of cylinder size ( ret.length ,extended length , piston size . ) you may need a flow restrictor in the lift cylinder line .
    Fifelaker and Stlshrk like this.
  3. Eric VW
    brenndatomu and walt like this.
  4. walt
    walt
    north central ohio
    I have a dual spool valve that I think I got from Rugged Made ,one side is the splitter valve with detent the other side is the log lift valve
