Wood Shed Idea
Discussion in 'The Wood Pile' started by TBONE, Feb 4, 2017.
  1. TBONE
    TBONE
    Carey, Ohio
    I thought this would be interesting wood shed idea to share. Some folks might be able to use and maybe even improve on. Hope fully I added the link correctly.
    rdust, Lone_Gun, papadave and 6 others like this.
  2. Certified106
    Certified106
    In The Hills
    I actually really like that idea......... It would be cool to build that on skids so you could drag it to where you wanted to stack. I wonder if you bend metal roofing to fit that so there was no need for tarps? I kind of want to try that.
  3. JustWood
    JustWood Guest
    That is a cheap easy idea. Those hog panels run about $35 each. Rubber roofing out of a dumpster. Bingo.
    That rooster would sound better inside my crock pot !
    Grahamt, Lone_Gun, Chvymn99 and 5 others like this.
  4. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    :sherlock: May be best for wood that is already, or, almost seasoned. Seems the wood is stacked too deep, covered too much and too close to the building to get sufficient air flow and sunlight to season it in a timely fashion. But then I'm just a fussy old cuss I guess. :BrianK:
    Chvymn99, papadave, Eric VW and 4 others like this.
  5. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    At my place wood only goes into a woodshed when it's dry.
    rdust, Chvymn99, papadave and 3 others like this.
  6. TBONE
    TBONE
    Carey, Ohio
    I was thinking the same thing if rubber roofing would work.
  7. Jack Straw
    Jack Straw
    It looks like you'd have to bend over quite a bit loading and unloading it.
    Eric VW and Backwoods Savage like this.
  8. TBONE
    TBONE
    Carey, Ohio
    My thought was if a individual doesn't have a wood shed that this might be an inexpensive way to store your seasoned wood. Never hurts to toss out new ideas that maybe one individual could use.
  9. JustWood
    JustWood Guest
    Could build it narrower with a higher arc =less bending.
    Might sacrifice stability though .
    I suppose you could run wire or rope through stack half way up to improve stability.
  10. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Ralphie,
    I agree. I would only make the bin one panel deep. and double up the tarp or whatever.
  11. TurboDiesel
    Free skids and rubber roofing. Cheap storage!
    5 skids total. 3 on ground, 1 on each end. (about one years worth of wood)
    5'5" x 5'5" x 4'10" high = 3.25 cords. And NO cribbed ends!
    BigPapi, TBONE, Kyle Mulligan and 7 others like this.
  12. Backwoods Savage
    No skids; just saplings cut in woods. Cribbed ends. 9 cord of wood here. Was top covered in fall of that year.
  13. Eric VW
    Are ya saying to bend the length of the sheet over the hoop? I think would be pretty tough.... cut to the depth of the hoop (and many pieces at that), and "shingled" so to speak, perhaps?
  14. Horkn
    Used rubber roofing around here is never thrown away. The roofing companies sell it around here for firewood use, among other things. So unfortunately it's not free around here.
    I'll be making a traditional style wood shed , 3 bay 4 cord per bay on my house property this spring. Although this type would work for my wood lot if I wasn't worried about my firewood walking off. I'm not too sure of that not happening though.
    greendohn and Backwoods Savage like this.
