Wood racks
Discussion in 'The Wood Pile' started by Dan-VA, Jan 11, 2020.
  1. Dan-VA
    Dan-VA
    Chesapeake, Va
    Here are my first wood storage solutions. The rack with the tin roofing is my seasoned wood for burning this year and the tote is wood felled this year seasoning for next winter. These are both inside wood, I'm currently working on an outdoor wood section. Pics to follow. [​IMG][​IMG]
    Sent from my SM-G975U using Tapatalk
  2. Maina
    Maina
    Maine
    Welcome to FHC Dan-VA! :handshake:Great first post! Looks like you’re off to a wonderful start!:thumbs:
  3. TurboDiesel
    Welcome to the club, Dan-VA !:handshake:
  4. 460magpro
    460magpro
    usa
  5. Eckie
    Eckie
    I like the covered pallet rack, I'm planning on making several similar to that. And what a stack in the ibc crate! Welcome, you'll like it here...lots of great people with great information and encouragement to share!
  6. Dan-VA
    Dan-VA
    Chesapeake, Va
    Thanks, the covered rack only took about 30 minutes to fab and that includes the time for cutting the tin roof to size, luckily I had some old tin roof laying around. I get the totes pretty regularly from work so I can definitely see a lot of those being used in the future.
  7. Eckie
    Eckie
    I would love to have a bunch of those totes, then i could load when i split and move them with the forks on the tractor.... What!!?? Only touch the wood once till ready to burn!?! That would be awesome!! But alas they're like $75-$125 around here...
  8. buZZsaw BRAD
    Hi Dan-VA and welcome to the FHC! :handshake: Great to have you join us! I like them. Simple and effective. The IBC totes are popular on here. Ive never used them but if you get them free you cant beat the price.
    We're great repurposers on here!
  9. farmer rob
    farmer rob
    Dundalk Ontario Canada
    touching the wood only once with racks is Great .I have 20 home built ones double stacked in my one shed is sweet for sure
  10. imwiley1
    imwiley1
    Wisconsin
    Welcome to the club Dan-VA Nice looking stacks!
  11. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I got access to almost a warehouse full of them basically free for the taking. About an hour’s drive to get em. I’ve just never figured a way to work them into my situation
  12. Sandhillbilly
    Sandhillbilly
    Welcome Dan-VA you’ll never look at a tree the same way again :tree:
  13. snaple4
    snaple4
    Nice cover. I need to do something to cover mine but I always end up having an excuse not to build one. The most recent: wife wanted a hot tub. So I had to spend money on a slab, on a used hot tub, on the chemicals and replacement parts, on the sub panels and wire (I will confess that I wanted this) and so on. Total tally comes out to about what I budgeted for a large wood shed... o well, beats having my wife hanging me in my sleep.
    One question though, is that all the wood you expect to use for the winter? I can go through all that in a week or two.
  14. Reddingnative
    Reddingnative
    Hornbrook, CA
    :rofl: :lol: This had me rolling. I was a little nervous last time I brought home a new saw, but it was fine and we are pretty balanced.
  15. Yawner
    Yawner
    Louisiana
    A consideration... there is someone on here who puts wood in homemade pallet boxes kinda like that... puts a 'sacrificial' pallet under each one to keep the main pallet from rotting from touching ground.
  16. Chaz
    Chaz
    Southwestern NY
  17. Dan-VA
    Dan-VA
    Chesapeake, Va
    No, this is not all the wood, I have a few other piles. This is a new thing i was trying out to try to avoid using tarps for the next pile I will be burning. It holds just a little shy of a cord.
  18. Dan-VA
    Dan-VA
    Chesapeake, Va
    That's a good idea. I've thought about using the plastic pallets for the base as well.
  19. sirbuildalot
    sirbuildalot
    Mass
    I was about to type this as well. The pallets touching the ground will rot in a year or two if left touching the ground. Could use sacrificial pallets as suggested. Could also use pressure treated 4x4, 4x6, or 6x6 runners. Could even use straight small diameter logs as runners. I’d use a durable wood like Red Oak, or Black Locust. This setup will also enable easier loading as it will be higher off the ground (less bending over), and will allow better airflow under the split wood which in theory should speed up seasoning time a little bit.
  20. MikeInMa
