Wood Processing Area Ground Cover?
Discussion in 'The Wood Pile' started by scarps68, May 5, 2022.
  1. scarps68
    scarps68
    CT
    I'm going to be expanding my wood processing area. I'm curious what, if any, ground covering you might lay down; stone, splitting remnants, etc.
    I have 3/4" stone in one area, but I'm not too impressed. Doesn't make clean up any easier.
  2. buZZsaw BRAD
    I use all the sawdust, noodles, bark, splitter crumbs etc. Keeps the mud factor down.
  3. amateur cutter
    Wood chips from my chipper and others. Got about 3/4 of an acre covered with em. 8-12" deep. Nice soft dry surface to work on, and if you run a chain into it, no immediate damage.
  4. Stihl Kicking
    Stihl Kicking
    Missouri
    I have a few old sheets of plywood I laydown, if it’s temporarily in the yard.
  5. Backwoods Savage
    Mother Earth.
    scarps68, M2theB, Biddleman and 7 others like this.
  6. The Wood Wolverine
    If I want the area cleaned up after a long splitting session, I lay down some rubber roofing material and work over that. Most times it's just ground and I rake.
  7. Casper
    Casper
    9.00 per ton sandstone from a somewhat close quarry for a base. I need to top it with some gravel or limestone as it has broken down on the surface and turns to a sandy type mud. I plan to expand the hard packed surface this summer if time allows. I hate working in, and driving the tractor, in mud.
  8. jo191145
    jo191145
    Ct
    Sawdust from Black Locust. It doesn’t rot :)
  9. Hinerman
    Hinerman
    NE Oklahoma
    No problem with termites and ants?
  10. Sirchopsalot
    Sirchopsalot
    medium city in CT
    An old concrete pad, used to be a garage or something here on the 'stead. I run the machine there. Its not so good for hand splitting, so I've gotten in the habit of splitting at the scrounge where I can.
  11. LordOfTheFlies
    LordOfTheFlies
    NY
    I work on asphalt. I was considering getting a few of those large horse mats that are 3/4" but 3 years in using just asphalt I think it's fine.
  12. Biddleman
    Biddleman
    River Hills of Pennsylvania
    I just let the bark, saw dust go, spread it out. And let the grass, errr. I mean weeds grow.
  13. amateur cutter
    Not so far, cold enough up here that termites aren't a huge issue. Processing area is well away from structures as well.
    Hinerman and Backwoods Savage like this.
