Wood ID
Discussion in 'The Wood Pile' started by ReelFaster, Jan 12, 2026.
  1. ReelFaster
    ReelFaster
    S.Jersey
    Grabbed this few weeks back at the garage where I work, little cherry mixed in at the bottom but the top rounds I wasn't sure what it was? Kinda looked like Mulberry to me a bit but am not great at this wood ID stuff. Thanks in advance!
  2. ReelFaster
    ReelFaster
    S.Jersey
  3. buZZsaw BRAD
    Bark looks like white walnut aka as butternut. Are those cut ends wet? I don't recall the heartwood being that dark when I've cut it.
    Split a few and check for a center pith. IIRC correctly WW has a chambered center pith.
    If it is it dries fast and splits easily. Low BTU but free is free.
  4. buZZsaw BRAD
    You'll know mulberry once you cut it as the bright yellow mustard color wood is unmistakable. It weathers to a dark brown.
    WeldrDave, jrider, Horkn and 6 others like this.
  5. ReelFaster
    ReelFaster
    S.Jersey
    Thanks much :handshake:
    These have been sitting for a good while over at the garage yard (up off the ground). Once this weather breaks a bit I'll be doing some chopping.......
    No those ends should be dry and dark like that when I snagged them.
  6. buZZsaw BRAD
    Just happened upon a pic of white walnut I scrounged back around labor day. DSCF0004.JPG
  7. RichE23ACR
    RichE23ACR
    Hunterdon, NJ
    I am not knowledgeable about many trees, and didn't know white walnut existed. I think I'm burning some tonight. It's noticeably heavier than black walnut. 20260113_164444.jpg 20260113_164428.jpg
  8. buZZsaw BRAD
    Thinking yours might be ash. Not 100% sure though. WW is rather light when dry.
