Wood ID help
Discussion in 'The Wood Pile' started by jtstromsburg, May 18, 2019.
  1. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Dumping grass at local dump and there’s piles of this. I suck at ID-ing species unless standing with a label on the tree
  2. Chvymn99
    Leaves speak of elm...
  3. jtstromsburg
    jtstromsburg
    That was kinda my assumption as that’s over 50% of the trees in my town. May go cut on the really dead stuff and see if it’s any good. I seem to have access to lots of better trees but all need time to dry and I’m starting off bad next winter. But if this is still solid, the bark-less stuff would probably be gooder if css now.
  4. TurboDiesel
  5. buZZsaw BRAD
    Im jumping on the elm bandwagon as well jtstromsburg Maybe red elm? Not a fan of any elm as i split by hand!
  6. jtstromsburg
    jtstromsburg
    Most of the elm here is referred to as Chinese Elm but not sure they are for sure. I have a hydro to split with and most of my wood is yard trees so twisted and full of limbs. It all sucks to split usually. Hoping I can go grab what’s there tomorrow.
    Chaz, Felter, amateur cutter and 13 others like this.
  7. buZZsaw BRAD
    Ive split fresh cut frozen green elm in the Winter rather easily by Hand. I snagged some "roadkill" red elm two Winters ago, fresh cut green. At the time i didnt know what it was. Heavy and dense and TOUGH to split by hand. The other mustve been white elm.
    The pics you posted looked like decent stuff...grab it if you can. Knot free is for me as i always say!
    Chaz, Felter, amateur cutter and 12 others like this.
  8. Barcroftb
    Barcroftb
    The Mitten
    Mayhap its slippery elm or Siberian/Chinese elm. One things for sure it'll burn better than a snowball!:whistle:
  9. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Yep, elm. Go get it, cut it into rounds. Split it up this winter when it’s frozen, since you have hydro splitter. And it might be ready for the 2020/2021 season. Part of your 3 year plan, just not the first part.
  10. Sandhillbilly
    Sandhillbilly
    I Don’t really know one elm from the next either. Hear lots about Chinese elm around here also. IMHO none are very good trees to have in your yard, very messy! But I like how it burns. Standing dead with the bark falling off is my staple wood
  11. Horkn
    Yes, the leaves say it's elm.
  12. Heat550
    Heat550
    Minnesota
    Yep I smell elm . Do they call it slippery elm be cause it slips out of the splitter . Here we called it pizz elm ... I think if you dry it you need to burn it before it rots . Elm kind like yep it burns .
    We got a bunch elm once it got rotten before it dried . Burned a bunch wet Ash once . I Think BTUs I got out of it was just enough to keep it burning .
    Ok smoldering . lol.
    Sent from my LGL84VL using Tapatalk
  13. jtstromsburg
    jtstromsburg
    Load two getting stacked. If I can get one decent evening this week I’ll get split n stacked. Lots of bark less ready to burn elm there. Though not as good btu wise, itl be ether than wet wood and most definitely better than burning a snowball as was said above
    Hmm pics didn’t post first time. Sorry fellas
  14. Chvymn99
    Elm tends to season quickly, good shoulder season wood, and has good fire starters attached to it usually.... I like to keep some it in the stacks... you did good...:handshake:
  15. jtstromsburg
    jtstromsburg
    Load three for the day. Not bad for a couple hours of saw time and a couple mile run back n forth. Loving my $150 tilt bed trailer. It may be small but sure easier to load and unload than my truck. Nice to grab load n a half each time !
  16. buZZsaw BRAD
    great work and score jtstromsburg. Nice when its that close to home! Nice that they let you cut there as well! Great buy for $150 IMO
  17. jtstromsburg
    jtstromsburg
    I’ve always been surprised they let anyone go cut out of the pile. It’s a free tree / grass dump and I’d guess if there’s ever any kind of incident at all, they’ll close it for sure. I’ll keep enjoying it till then. Supposed to rain all week but will have to keep grabbing what I can till it’s gone. It was funny, as my neighbor had a large tree dropped this morning and they’re hauling all the limbs and little crap out as I’m cutting and bringing stuff in. I helped with two very large limbs last fall on their same tree but they think the woods worth money even after I did all the cutting... I’ll probably help them cut this batch up too if they ask. Just gotta get mine done first.
  18. Karvinkanuck
    Karvinkanuck
    Slippery Elm
    Beause the bark when eaten... if your that hungry will .. let's say prepare you for a colonoscopy
    pizz Elm well that is what it Smells like , around septic fields it is especially bad
    Two different species
  19. amateur cutter
    Siberian Elm I think. Grab all you can, decent firewood & seasons quick. Good score!
  20. Heat550
    Heat550
    Minnesota
    What's different between pizz elm and slippery elm .? I think all elm burns like elm . Now it grows over septic systems to I never new that . Is that sewer elm ?
