Wood Glue
Discussion in 'The DIY Room' started by thewoodlands, Aug 24, 2017.
  1. thewoodlands
    thewoodlands
    I need some advice, I'll be doing a small project that will require gluing small strips of wood together in a circle. I would like to use a glue that won't leave any color but is also easy to work with, what type of glue should I use?
    Thor and My IS heats my home like this.
  2. papadave
    I always use Titebond. If the joints are tight, you won't see the glue after cleanup.
  3. lukem
    How strong does it need to be and how difficult is it going to be to get things into position (working time).
    Not super strong you could use super glue but it has a short working time. Epoxy is strong and has a longer working time. Yellow glue is still the strongest.
    Thor, thewoodlands and papadave like this.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    I second that. I've been using titebond for many years with no complaints
    Thor and papadave like this.
  5. papadave
    Yep, the regular Titebond has the longest open/working time of the 3 Titebond types.
    Does it need to be waterproof?
  6. HDRock
    Yep, Titebond
    Titebond Original
    Application Temperature
    Above 50°F.
    Open Assembly Time
    4-6 minutes (70°F./50%RH)
    Total Assembly Time
    10-15 minutes (70°F./50%RH)
    Not water proof
    Titebond III Ultimate
    Above 47°F.
    Open Assembly Time
    8-10 minutes (70°F./50%RH)
    Total Assembly Time
    20-25minutes (70°F./50%RH)
    Waterproof formula that cleans up with water
    interior and exterior applications
    Longer open assembly time
    Titebond Translucent Wood Glue
    Virtually invisible glue line
    Fast set - Strong bond
    Not water proof
    Above 50°F.
    Open Assembly Time
    Total Assembly Time
    Thor, milleo and papadave like this.
  7. thewoodlands
    thewoodlands
    I wood like to put a nice clear coat of something on it, I also might stain it before, it just depends on what type of wood I use.
  8. thewoodlands
    thewoodlands
    I'll be doing a wooden ring for a finger.
    Thor likes this.
  9. lukem
    Are you going to be able to clamp it?
  10. thewoodlands
    thewoodlands
    I hope so. :whistle: I'll be making a trip into a hardware store to look at some smaller clamps or get some ideas on the best way to do it.
    Thor likes this.
  11. thewoodlands
    thewoodlands
    I just read online that one person used a rubberband or a strap, I believe he used a dowel that he would wrap the strips around.
    Thor likes this.
  12. lukem
    If you use ca glue and an activator you wont need to clamp it. Since their wont be any tensile stress of a ring the ca glue should be strong enough.
    Thor likes this.
  13. lukem
    That would work if you had a dowel the size of your finger.
  14. thewoodlands
    thewoodlands
    That was my plan.
    Thor likes this.
  15. Thor
    Thor
    Genoa City,Wi
    :ithappened:
    HDRock and thewoodlands like this.
  16. HDRock
    Are you using veneer?
    Thor likes this.
  17. thewoodlands
    thewoodlands
    Thin shavings from whatever wood I use, I'm hoping a small hand plane will work.
    Thor likes this.
  18. lukem
    If the shavings are too thin yellow glue will soak through and won't take a finish. Make sure you do a test piece first no matter what kind of glue you use.
    Thor, papadave and thewoodlands like this.
  19. thewoodlands
    thewoodlands
    Thanks.
    Since I'll be getting everything in the next three days, what glue, stain and clear coat would you use?
    Thor likes this.
  20. lukem
    I'd like to see some pics of the pieces you are going to glue up first. Hard to say f[r sure without them.
