Winter shutter reminder and question
Discussion in 'Chainsaws and Power Equipment' started by Dakota Hoarder, Dec 23, 2018.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    reminder to put your winter shutters on your saws. I have to admit I’ve forgotten many times, but it never had any problems.
    What is the temp that shutters should be put in the winter position?
    Who wants the responsibility to remind us horders to put shutters back it summer position when it warms up??...
    M2theB, Horkn, Hammy and 6 others like this.
  2. amateur cutter
    Thanks, now I've got something to do tomorrow. They may still be in the winter position from last winter LOL.
  3. MikeInMa
    Shutters? What might those be? I know of the type that go on windows. Guess I'll be firing up the Google
  4. brenndatomu
    Only "better" grades of saws have them (maybe only pro saws?) my Craftsman saw doesn't have shutters :whistle:
    In effect, the shutter recycles some of the warm air coming off the saw, back into the intake area...helps maintain the saws normal running temp in cold weather...also, and probably more importantly, helps to maintain the fuel/air mixture ratio on carbureted saws since cold air is more dense, real cold air can make things that are extra sensitive to fuel air ratio (like 2 stroke saws) run lean (and we all know that's BAD!) :startled:
    M2theB, farmer steve, Maina and 9 others like this.
  5. Erik B
    Erik B
    Western Wisconsin
    My Stihl 029 super has the shutter for winter/summer use
    M2theB, Hammy, Dakota Hoarder and 5 others like this.
  6. Horkn
    Yep, so does my dolkita. Thanks for the reminder, I'll be firing my dolkita up today, attempting to burn up the last of my gas from October.
    Like brenndatomu says, all decent saws have these.
    M2theB, Hammy, Dakota Hoarder and 4 others like this.
  7. In the Pines
    In the Pines
    my homeowner grade stihl and husq have them.
    M2theB, Hammy, Dakota Hoarder and 3 others like this.
  8. Nixon
    Nixon
    West Sunbury,Pa .
    My 044 doesn’t have a winter shutter / diverter . It’s mentioned in theowners manual ,but there isn’t one on the saw .
    M2theB, Hammy and amateur cutter like this.
  9. brenndatomu
    I wonder if the flapper is just missing...my "MU-SHU" 660 (chinese Stihl 660 kit) didn't come with the shutter either...some did, some didn't...I can't imagine it costs much...not sure if it is worth worrying about or not though...I haven't ran it in the winter yet.
  10. Ronaldo
    Ronaldo
    If I'm remembering my Jonsered 2152 owners manual correctly or any of the manuals from multiple saws I've owned/own, they recommend using the winter setting when temps get to 10F or lower. I cut throughout the winter here in Iowa and I'll change the shutter if I remember but I've not noticed much, if any,difference from either setting.
    Sent from my SM-S320VL using Tapatalk
  11. Horkn
    I didn't run out a tank of gas in the dolkita, but I ran it long enough to get all of my too long pieces shortened to fit north/ south in my insert, as well as cut all of the remaining pieces of the ash I had that were needing to be bucked.
    It was just as easy to change the dolkita to winter mode as it is on the 029super.
    M2theB, Hammy, brenndatomu and 2 others like this.
  12. Nixon
    Nixon
    West Sunbury,Pa .
    Nope,not missing . There is nothing in the partition wall where the manual states there is one .
    To be honest , even on my sawswith the winter flap , I never use it .
  13. JustWood
    JustWood Guest
    About the only time they are necessary .That and deep snow . The constant melting of the snow (steam)and high air flow will ice up the carb . If anyone had sleds back in the 70s, you'll remember the old tillotson carbs having frost all over them when it got real cold and deep snow .
    I've drilled holes in the firewall and used duct tape or ear plugs to close them off in the warm seasons .
    M2theB, Horkn, Hammy and 4 others like this.
  14. Ronaldo
    Ronaldo
    The above would be a more important move......dont want the extra heat in high temps.
    M2theB, Horkn, Hammy and 3 others like this.
  15. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Cleaned and sharpened my 260 last night (haven’t used it since last summer, my 026 has Ben getting more work) I still had the shutter in the winter position since who knows when:hair:. Oh well, it ran just fine!
    amateur cutter, M2theB, Horkn and 3 others like this.
  16. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    The manual for my 362, 461 and 661 all say to flip the shutter below 50°f. to prevent carb icing.
    I usually do but have forgotten many times and never had a problem.
  17. Fifelaker
    Fifelaker
    Fife Lake Mi.
    None of my saws have them and I have cut in below zero temps many, many times and never had an issue. I will tune the saw after it gets to operating temperature though, sometimes I will have to re-tune through out the day due to a freak warming.
  18. Hammy
    Hammy
    New Brunswick
    My 261cm version 1 manual says the same.
    Thanks for the reminder Dakota Hoarder
  19. MasterMech
    These are only “necessary” to combat carb icing. That’s not even a real problem in real cold temps as carb icing really only happens just above or near freezing. Introducing moisture , ie. from snow, would also be problematic but personally I’ve only had a saw exhibit carb icing once and it was 38 deg and raining. Not my favorite cutting weather!!
  20. Fifelaker
    Fifelaker
    Fife Lake Mi.
    I have a friend that was almost killed in a plane crash. It was around 70° and he was on his final approach, the tower called him off because another plane was low on fuel. He shut off the carb heater and forgot to flip the switch back on, he circled twice and the engine died just off the end of the runway. The humidity was higher than the ambient temp that day which was the major cause of his carb icing up
