Why clean the stove when switching fuels??
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by dotman17, Jan 6, 2018.
  1. dotman17
    dotman17
    Snohomish, Washington
    So i have read it's suggested to clean your stove every time you switch pellet fuel. Anybody know why this is recommended?? I am speculating the main reason is to help isolate fuel problems. But is there an immediate concern of not doing so? I could see following this procedure after burning a ton of this and a ton of that, but what about 3 bags of this and 7 bags of that?? Who made up this nonsense and why should I follow it? If you are one that goes by the book, how often do you do this and how literal do you interpret it?
    Just curious.
    CleanFire, ivanhoe, imacman and 3 others like this.
  2. will711
    will711
    Pocono Mts.
    Toss that book in the trash , I've never cleaned after changing brands :loco: :crazy: No issues
    CleanFire, Luneyburg, ivanhoe and 5 others like this.
  3. ttdberg
    ttdberg Pellet Pig
    CT
    X2 it’s certainly not required or some kind of standard. Only time I could think that would apply is if I were trying to gauge the dirtiness / ash output of a new brand I never tried before.
    CleanFire, Luneyburg, ivanhoe and 4 others like this.
  4. slvrblkk
    slvrblkk
    Northampton, PA
    X2...I do it to see what the "new" pellet is like. Probably because I test pellets too so it's a little in me to clean before I switch. I actually did it this morning. I did a full clean with the LBM and now I'm running Chow's to see what they're actually like.
    CleanFire, Luneyburg, ivanhoe and 3 others like this.
  5. IHATEPROPANE
    IHATEPROPANE
    X3 Not really necessary IMHO
  6. subsailor
    subsailor
    Winthrop, Maine
    I don't either. I mix at times as well.
  7. bogieb
  8. ivanhoe
    ivanhoe
    Northern Ontario
    I mix as well but empty hopper to introduce newer pellets for heat comparison. I usually do that on a clean slate which is rare these days:smoke:
    CleanFire, imacman, Luneyburg and 2 others like this.
  9. Luneyburg
    Luneyburg
    Hills of Central Mass
    Same here only when I want to check out in comparison a new batch or kind of pellet otherwise your looking at the mixmaster if my stoves were turn tables i might have not had to go into the construction business :cool:
    ivanhoe, slvrblkk, CleanFire and 3 others like this.
  10. bogieb
    Even when taking temps at the airstream and/or above the door, I don't account for whether the stove is clean or dirty. I figure that the stove is "dirty" 99.99% of the time so what do I care what a pellet does in a clean stove? I am more interested in how it performs when there is ash on the sidewalls and outside the air tubes.
    ivanhoe, Luneyburg, slvrblkk and 4 others like this.
  11. CleanFire
    CleanFire
    Wow, you can certainly tell the Harman & Englander owners in this thread.. :whistle: "Throw it in there, it'll burn ANYTHING!" :thumbs:
    In the minority here: like Steve, I'll do a deep clean & empty Hopper when testing a new brand pellet I'm really interested in: to compare vs. what we normally burn / to give it a "fair shake" in the stove. * But really more interested on checking for any buildup, post test-burn, on the small stove here.
    imacman, ivanhoe, Luneyburg and 3 others like this.
  12. badbob
    badbob
    Never heard of this,post a link?
    bogieb and IHATEPROPANE like this.
