Whoops!
Discussion in 'Chainsaws and Power Equipment' started by saskwoodburner, Feb 16, 2016.
  1. saskwoodburner
    saskwoodburner
    Not sure how this happened, but it could have been worse!
    HDRock, wildwest, papadave and 2 others like this.
  2. papadave
    Always have an exit strategy....and use it.
    HDRock, wildwest and Stinny like this.
  3. Stinny
    Yep... it tried to get him... and it couldn't do it... lucky dude.
    wildwest, papadave and Shawn Curry like this.
  4. Shawn Curry
    Shawn Curry
    Western NY
    Good thing he was wearing a helmet. You really only need to step a couple feet back. My close call I basically did the same thing as he did. I was pushing over a broken off top that was already on the ground but leaning on another tree. Then I just stood there and watched it go over. The butt end kicked up and came inches from catching me right in the jaw. Stay safe out there.
    HoneyFuzz and wildwest like this.
  5. savemoney
    That seemed to be a freak accident. But he could have done more with the proper clothing and protective gear
    I've been whacked before out of ignorance and circumstances. It is a wonderful worse didn't happen to me. :headbang:
    wildwest likes this.
  6. WV Mountaineer
    WV Mountaineer
    Princeton, WV
    They are called widow makers for a reason. The top of the tree breaks out and usually falls into the area the cutter is standing. It is very common in dead timber. When the tree finally starts to fall, the movement reflexes up the trunk like a little wave. It causes a whip effect when the top starts to fall. Often breaking out rotten tops and limbs. It has likely killed more timber cutters than all other accidents combined.
    A few feet won't cut it. Get out of there when it starts to fall. Wedging is bad too in these trees. It's best to notch it and come straight from the back. Use a wedge if the tree tries to set on your bar. Don't go to beating on it either. Just get the back cut deep enough to put it in for insurance. Then put it in! Keep cutting and leave a hinge. If it won't fall, hit it with another tree or, flag off the area and allow the wind to do it for you. Whatever you do, don't go to beating on that wedge! It'll have the same effect as the tree starting to fall if you do. On the other hand, if it does fall, lock the brake and run boys. If the saw is slowing you down, pitch it. You had better be moving. A few feet won't cut it. Remember, It really is better to prep it and, just knock it over with another tree instead.
    Good cutters are smooth operators. But, if you watch one for a bit, you'll see him scurry sometimes. Take heed also that even when he walks away quickly, he moves farther than a couple feet.
    Four Saturdays ago I helped cut and deliver a load of firewood to a timber cutter that got his legs smashed OFF last winter. He moved about 10 feet back at his angle. The tree hung up and the hinge broke. He had his back to it when it hit him. If only he had moved another 10 feet. That tree drove his legs into the steep ground like putty in a hole. It's a sober reminder that a few feet won't cut it for long.
    Be careful and God Bless
  7. Eric VW
    Wow, tough ending story in your post WV Mountaineer :confused:
    Thanks for the firm reminder- well stated, young man!:)
    Shawn Curry, HoneyFuzz and wildwest like this.
  8. pantelis
    pantelis
    Europe
    just a stupid azzhole with a chainsaw
