Who uses a Mingo Marker?
Discussion in 'The Wood Pile' started by MMfrompa, Nov 12, 2017.
  1. MMfrompa
    MMfrompa
    Pa
    Do you care if your firewood is consistant lengths or not? Doesn't really matter I guess, but to me it does lol.
    Hammy, Lone_Gun, Boogeyman and 4 others like this.
  2. yooperdave
    Nope, nothing here.
    I occasionally get a piece that is too long, but very rarely at that and can usually fit them in diagonally. If not, fire pit or OWB gets them for a snack.
  3. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Yep, I use it. A good, functional tool. I just wish they made an 18" wheel.
  4. J. Dirt
    J. Dirt
    I’ve got a piece of 1x3 pine measured and marked 16”-18” and I’ll take that and a spray can and mark sometimes especially when I’m cutting with my dad and or brother because the 10”-30” lengths drive me nuts :picard::D
    By the way MMfrompa you make some sweet stacks!!! Not to mention all your other work I’ve seen in your videos! Nice job gives some of us :whistle:a goal to shoot for:handshake:
  5. yooperdave
  6. J. Dirt
    J. Dirt
    Yep I watch them go on the truck:picard:watch and handle them off the truck :confused: then trim some and send some to the ugly pile :headbang:.
    Oh did I forget enjoying every minute cutting with the guys :D
  7. MMfrompa
    MMfrompa
    Pa
    10 - 30 lol
  8. Mag Craft
    Mag Craft
    South East Wyoming
    I use side walk chalk and one of those freeby tape measures from HF.
  9. scavenger
    scavenger
    saybrook township ohio
    I have a friend who marks out his cuts and I just shake my head. Just eyeball. How hard is it to hit 16 inches each time? To me it's a waste of time.
    yooperdave, Steve and Flatlander Pete like this.
  10. JCMC
    JCMC
    Just outside of Shushan, NY
    OWB will take 32" I just eyeball and cut everything around 22" - 24" if it is to short or to long it doesn't matter it all burns.
  11. gboutdoors
    gboutdoors
    S.E. Massachusetts
    Had one liked it as I stack on four foot pallets and three sixteen inch splits stack nice. Let a friend borrow it two years ago. Now I have a stick marked at 16” and a paint can.
    I can’t cut the same size rounds to save my life so marking is the way to go for me.
  12. Backwoods Savage
    It sounds as if some teaching is in order? It is more enjoyable when the work is done right.
  13. Moparguy
    Moparguy
    TN
    I have a mark on the saws. I hold the saw over the log, line up the mark on the end of the log and see where the tip of the chain is, then cut it there. It's fast and easy.
  14. Backwoods Savage
    walt has something like the Mingo marker and he likes it.
    Rather than buying paint and then keeping it from freezing or being messy, I like the simple method better. A simple carpenter's crayon can be bought pretty cheap and they last for years. We also have a crayon holder which keeps the crayon from breaking and it is easier to hold on to. I noticed that Home cheapo has these in stock now too.
    For the measurement, we just use a simple stick cut at 4' and marked at 16" and 32". this gives us 3 marks with the 4' stick. Some have mentioned rightly that when the wood is really wet or punky then the crayon does not work so well. Not a problem. At those times you simply use the axe or a hatchet and simply draw a line for the mark. Simple and easy.
    You can see our measuring stick in the first picture. And btw, DexterDay really fell in love with our method of marking.
  15. J. Dirt
    J. Dirt
    Messy paint? Some of you may remember my oops last fall when I tossed the paint can a little to close to my saw and a tooth punctured the can 168DB5B1-B010-43A4-82FA-7A4A79908455.jpeg
    As far as the 4’ stick I like that better than my little single cut one F669CB8D-8294-4201-B89A-4C6751746E81.jpeg
  16. Boogeyman
    Boogeyman
    Central Indiana
    I've got alot of that 10-30 inch stuff around, if my dad or my father in law happens to cut any wood they like "eyeball" measurements. Didn't use to matter when I was feeding dad's neighbors boiler, but now that he has passed it's just sitting around.
    Your stacks are something to behold Mmfrompa! I do believe consistency in length is quite important to neat stacking
  17. Will C
    Will C
    New York
    My brother and I used a Mingo marker for a couple of years until it broke. It worked well. Now we are back to a story stick and paint or crayon.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I use the Mingo, find that it works well especially on those not so straight trees.... My shed takes 4 rows of 16" wood, stacks easily that way and my stove is designed for 16" legnths. If its over its a pain in the azz if its under it goes to the ugly stack
  19. Kimberly
    Kimberly
    The Kangaroo State
    I guess that would work if you cut short each time. However, every cut you make is fuel and oil and wear on the chain; so the fewer cuts the better. A stick of firewood too long is a stick of firewood that won't go into the stove and if you find that out after putting it in the stove and it has caught and burning, then you have a safety hazard as you try to get it outside not too mention smoking up the house. I want my firewood to be the proper length and a few centimeters too long means it won't fit. So, I am not going to guess because I have found out that guessing means the sizes could easily be too long. I am currently using stick and mark method but I also note where the size is on the bar and often will use the bar; although that is not as precise as I place the bar, mark the spot in my memory, and then have to move and put the cut where I mentally mark it; that takes much more time than just measure stick and mark before starting the bucking of the log.
    To each their own I suppose; your guessing measure and my precise measure; one works for you and one works for me.
    Lone_Gun and gboutdoors like this.
  20. Kimberly
    Kimberly
    The Kangaroo State
    Yes, but it turned your saw into a work of art :D
    J. Dirt and gboutdoors like this.
