What's the verdict on Fords aluminum bodies, how they holding up?
Discussion in 'Chainsaws and Power Equipment' started by Softwood, Jul 27, 2022.
  1. Softwood
    Softwood
    Central WI
    I'm looking at updating my old '06 F150. I know in '15 they switched to the aluminum frames. Just wondering how they are holding up for everyone and/or what you have heard? Especially in the midwest, with long winters and TONS of SALT on the roadways :hair:.
  2. Chvymn99
    Mines holding up fine, so far.... But I'm a regular washer in the winter time...
  3. brenndatomu
    I think the frame is steel, the body is aluminum, no?
    I remember reading about the special body mounts they had to invent to stop the galvanic corrosion between the 2 metals
  4. isaaccarlson
    isaaccarlson
    Colfax, WI
    I have been around a few. So far not impressed. Not enough weight to control a trailer.
    Chvymn99 and Softwood like this.
  5. Softwood
    Softwood
    Central WI
    Maybe?
    Horkn and Chvymn99 like this.
  6. Chvymn99
    Correct frame is steel... Bed is aluminum...
    Horkn, hovlandhomestead, Ohio and 2 others like this.
  7. Chris F
    Chris F
    Micksburg, Ontario
    The entire body is aluminum. Cab, doors, fenders, hood and box. Frame is still steel.
  8. Eric VW
    Thread title edited.
  9. hovlandhomestead
    hovlandhomestead
    MN
    I have been wondering about the aluminum body Ford F-150s as well. Salt and rust are constant battles here too.
    My 2006 Tundra is still holding strong - just a little surface rust here and there. I religiously coat our trucks with fluid film, and am now trying out the new PB Blaster surface shield product that is supposed to adhere better than the FF. It is a petroleum product I believe and requires good ventilation or breathing protection. Seems to be a good product.
  10. Warner
    Warner
    Ford has been using aluminum panels since the early 2000’s. Early on there was big problems, they seem to have ironed it out for the most part. Lately most of the oxidation comes from pits in the paint.
    If I was buying a used vehicle in the rust belt I’d me more concerned with the frame. I have seen many vehicles that look great on the topside but the frame is rotted out.
    Horkn, eatonpcat, Softwood and 2 others like this.
  11. hovlandhomestead
    hovlandhomestead
    MN
    You are right Warner. I do my interior body panels once every few years, but the frames on our trucks are under constant surveillance, and re-coated twice a year, and touched up in high spray areas anytime it is needed. The PB product is supposed to adhere better to road spray areas than the FF.
  12. Softwood
    Softwood
    Central WI
    Thanks!
    Horkn, Eric VW and eatonpcat like this.
  13. Softwood
    Softwood
    Central WI
    No doubt!
    Horkn likes this.
  14. Horkn
    I've got a '16 lariat. No issues with paint/ rust/ body. They did the right thing when it comes to the body panels being aluminum.
    As far as weight, the new GM's are lighter than the alloy bodied f series. Sure the body on the fords is less weight, but the frame and running gear are all heavier in weight and HD - ness than the GM's. I've heard that argument before about them not weighing enough and trailer loads, and it's simply not true.
  15. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    16” f150 lariat as well. No rust or oxidation issues at all. Paint and body looks like new. No problems towing. Actually tows my 4000 lb boat way better than any truck I’ve owned. Now gas milage while towing that’s a whole other issue:hair:
