What wood will warm up the house the fastest?
Discussion in 'The Wood Pile' started by RichE23ACR, Oct 13, 2025.
  1. RichE23ACR
    RichE23ACR
    Hunterdon, NJ
    Hi, when coming home from being out of the house for 10 hours & the woodstove is cooked way down to little more than embers and the house is chilly; what firewood puts out the most heat in the shortest amount of time? I do not know how to prove it. Personal experience has me loading up a bunch of DRY pine or spruce, split on the smaller side with the damper at full throttle This seems to warm the house way faster than any hardwood I've tried.
    Has anyone formally studied this? The vast majority of Google research that I've done comes back with BTU's/cord.
    FTG-05, KSPlainsman, wildwest and 8 others like this.
  2. Ronaldo
    Ronaldo
    I’d say you’re doing right. The soft woods will light and get up to heat quicker. That’s my experience.
  3. JimBear
    JimBear
    Well, the proper answer is, dry wood.
    I like your way of thinking that some pine will get a fire going & hot, quick, fast & in a hurry.
  4. Husky Man
    Husky Man
    Mt Hood Oregon
    Softer woods(if DRY) will create heat FASTER,
    Harder woods have a higher latent BTU value, but release heat Slower over a longer time
    I have never used it that way, but I suspect that Cedar would produce some of the highest temps faster than any particular wood that I can think of, but I wouldn’t recommend burning 100% Cedar splits for very long, especially with the draft wide open
    Cottonwood is another that will produce heat fast with the draft open, again with the caveat that it is Dry, and in my experience leaves little ash
    Doug :cheers::usa:
  5. Dunmyer mowing llc
    Dunmyer mowing llc
    Indiana
    I like pine a lot for quick heat I'm sure spruce is around the same.
  6. Backwoods Savage
    My goto has almost always been soft (red) maple. Not only for quick heat but it makes excellent kindling too.
  7. Krackle_959
    Krackle_959
    Coastal Maine
    We use pine and poplar for kindling to get a fire started. I’ve also got several cord of poplar for shoulder season wood this year and it will warm up the house in short time. There’s only a few spruce trees on the property so I haven’t tried spruce yet.
  8. jrider
    jrider
    Looks like we all share the same mindset. Woods that are lower on the btu scale but burn quickly. They release a lot of heat in a short period of time.
  9. JDU
    JDU
    Perry County, PA
    Agree with the others on this. I use dry hemlock to get the stove hot quickly.
  10. buZZsaw BRAD
    X2
  11. Husky Man
    Husky Man
    Mt Hood Oregon
    On the topic of kindling, Cedar has always been my “Go To” wood, but my old “Plan B” of old railroad ties split small and soaked in used motor oil works well too, a bit messy but you don’t need any newspaper, and lights well with just a match
    Doug :cheers::usa:
  12. iowahiker
    iowahiker
    NE Iowa
    Sugar maple.
    The choice of lower density woods like pine is not needed. Any wood dried and split small enough laid down in a criss-cross pattern will produce lots of heat (internal drafting with lots of surface area).
    I have a large grate and can lock on my 1000 cfm blower quickly with any size/specie DRY wood (wood-coal furnace), i.e. lots of drafting (triple wall stainless steel 8" chimney, jet engine).
  13. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Agree with others here. I used to have a lot of Cottonwood I’d use in the morning and right when I got home from work. I’d load up with a bunch of smaller splits and the stove would heat up fast. I actually miss having cottonwood around for that purpose.
  14. dave_026
    dave_026
    Redding, Ct
    A bit of a tongue in cheek response here, but I would say a properly placed fan to move the hot air from near the woodstove into the cold house is the #1 factor.
  15. Dok440
    Dok440
    NorCal
    You got it right. I keep a few ricks of pine for getting fires going.
  16. Scotty Overkill
    I like seasoned spruce for quick heat. I don't really keep much of it but I do quite a few spruce removals over the course of a year and end up with a handful of it stashed (I love it for cooking maple syrup down too), it puts out quick heat when you wanna get the temperature up.
  17. Timberdog
    Timberdog
    Az
    Pine.
  18. Ron T
    Ron T
    Northeast Ohio....Bowdil
  19. isaaccarlson
    isaaccarlson
    Colfax, WI
    We use doug fir for FAST heat.
  20. brenndatomu
    X2.
    I have some poplar toasting right now that is doing a great job too...
