What shape do you split ?
Discussion in 'The Wood Pile' started by intheBigWoods, Feb 10, 2016.
  1. intheBigWoods
    intheBigWoods
    central North Carolina
    When splitting large rounds do you give any consideration to the final shape of the splits? Do you split them square, or triangle, or rectangular? Does it matter? Is a mix of shapes best?
    I know with some wood there is not much choice because of knots. My question is when there is a choice.
    Maybe this is much adoo about nothing, but I have found myself thinking about this many times while splitting with a vertical splitter.
    What do you think?
  2. Unicorn1
    Unicorn1
    Amarillo, TX
    As long as its small enough that I can pick it up and it will fit into the stove.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Just smaller here. And wood shaped.:D
  4. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Rectangles because that what many of them naturally become.
  5. Erik B
    Erik B
    Western Wisconsin
    It depends on the size of the round being split. Smaller rounds give me triangle shapes and larger rounds may give me some square or rectangle pieces. They all have to be small enough to fit in the stove and easy for the wife to handle.
  6. JeffGu
    JeffGu
    Osceola, Nebraska
    I try to split all of mine into the shape of a toilet seat or a rolltop desk. So far, it's been a dismal failure.
  7. Frank and Beans
    Frank and Beans
    I'm happy with anything but a rhombus. I despise rhombus-shaped splits and I refuse to burn them.
  8. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I'm glad I'm not the only one, I've been trying for credenzas. No luck yet.
    1964 262 6, Eric VW, Oldman47 and 6 others like this.
  9. fuelrod
    fuelrod
    Western Maine
    I think you need a set of radio head phones to take your mind away:D th-1.jpeg
    Seriously, I shoot for a certain "volume" of wood in each split, couldn't tell ya how big it is, but I know it when I see it.:whistle:
  10. CTYank
    CTYank
    CT Panhandle
    I aim for the checks with a maul. They set the stage. Then, go for a serious mix of sizes/shapes. No cookie-cutting here!
    Rounds with serious knots/forks get sent to the "Group-W" pile for some later partway-noodling-therapy, then hit again.
    IOW, the plan is to have no plan, just swing that steel. Obsessively non-compulsive? Crank up the music and hold onto the headphones!
    1964 262 6, UncleJoe, Eric VW and 5 others like this.
  11. Shawn Curry
    Shawn Curry
    Western NY
    Really anything will do and having a variety of shapes and sizes works out pretty good. I know what you mean though - I split by hand so I do think about how I'm going split it. Some types of wood like to be split a certain way - pine likes to split radially but not so good the other way. Unless they're really stubborn, I like to split knots in half (any wood) because the pieces will usually be shaped nicer for stacking.
  12. fox9988
    fox9988
    NW Arkansas 72717
    On large rounds, the sapwood makes triangles and slabs. The heartwood makes rectangles.
  13. saskwoodburner
    saskwoodburner
    Prince Albert, Saskatchewan, Canada
    Is D shaped not an option? Frankly, I'm disappointed.:D
    My wood consists of lots of half splits, but mostly triangles.
  14. Scotty Overkill
    big clean rounds usually end up as nice squared-off splits, and I use those for cribbing the ends of the stacks.
    but as I've said before many times, I've got splits of all shapes and sizes......and they all fill up space in the stacks!!
  15. TurboDiesel
    I always try for squares, rectangles or three square sides and one side with bark.
    Square wood definitely burns better! ;)Especially after it's been stacked three years.
  16. FTG-05
    FTG-05
    TN
    I'm amazed at the small size splits that I did back when I started Oct. '13. In retrospect, it was probably good since those small splits (some hardwood, some softwood) seasoned and dried quickly.
    Now, my focus is C/S/S as much as I can as fast as I can. Which means my splits now are at least twice the size of 2 years ago! No matter, when you are 4-5 years into your 3 year plan as I am. If it's not seasoned and dried by 2020, yea whatever, I'll use it the next year.....
  17. Horkn
    If a round will allow a square or rectangular piece, or pieces, that is my goal. I'm always looking for the right split for corners/ cribbed ends as many here do. The rest, they all stack in between the cribbed ends.
    I'm fine with half logs though too. They stack and make nice cribbed ends too.
  18. Machria
    Machria
    Long Island, NY
    I make them parallelograms. You really need to learn the proper tequnique before you try it though!
  19. Eric VW
    I found myself getting into a rut with trying to split in the shape of Long Island. Guess I was waxing nostalgic at the time. Very labor intensive.
    Squares, 1/2 rounds and planks for cribbed ends, any other geometry is game for in the middle... a little variety is good for mixing it up and allowing for better airflow.:thumbs:
  20. Wood Duck
    Wood Duck
    I have a small stove so I want splits that I can stack without risk of tumbling into the glass, but also allow me to stack them pretty much vertically at the front. This means rectangles are best and I avoid triangular cross sections. I also find that I need at least three splits in the stove at a time to get a decent fire, and four or five works better. This means I can't make the splits too big.
    So the result is medium rectangles are ideal for me. However, with most trees being more or less round, I end up with all sorts of shapes.
