What pest is making this fine, sawdust like powder on my woodpile?
Discussion in 'The Wood Pile' started by Retired Coal Miner, Aug 17, 2023.
  1. Retired Coal Miner
    Retired Coal Miner
    PA
    I know it's some pest, insect.
    The splits above the small piles in the pics have very fine holes in them, on the bottom of the split and above the fine sawdust/powder. I never ever see anything, except the occasionally black ant that would not fit into the fine holes.
    What pest is doing this, and what if anything should I do to stop it?
  2. MikeInMa
    Most likely powder post beetles.
    Most every wood burner gets them.
    They'll move on once there's no moisture left.
    If the powder bothers you, get out a leaf blower!
  3. RCBS
    RCBS
    Over here
    "Angels' Share"
  4. Retired Coal Miner
    Retired Coal Miner
    PA
    I've never seen this before. The wood is from an new and untested source.
    And I'm planning to leave the stacks there for another 16 months. I hope these bugs knock it off and go away soon.
  5. FarmerJ
    FarmerJ
    Minnesota
    Looks like carpenter ants to me.
  6. Locust Post
    If you have some hickory in the mix it is hickory borers If not it's probably powder post beetles.
  7. buZZsaw BRAD
    Nothing to worry about. I get them in certain stacks in assorted species. Make sure the powder doesnt get wet or it cakes up.
  8. EODDiver
    EODDiver
    Nashville, TN
    Very prevalent in hickory. Even when I cut virgin hickory rounds and stack it quickly, the powder appears months later. Let hickory lay on the ground for a few months and the pests go wild on it. I sell a lot of white oak and one of the best attributes of it is that it doesn't attract pests. Seems ants love red oak. Stacking off the ground and top covering greatly helps keep the pests away.
  9. Backwoods Savage
    Does not look like powder post beetles.
    Chvymn99 likes this.
  10. Retired Coal Miner
    Retired Coal Miner
    PA
    Can you elaborate, please?
  11. Backwoods Savage
    Sorry for not answering right away as I was offline for a bit.
    This is from PPB. Notice how fine the dust is and compare it with your picture. I might add the picture doesn't give the real story but you will understand when you see it on wood. It is amazing how fine the dust is.
    Chvymn99 and The Wood Wolverine like this.
  12. Old Nate
    Old Nate
    Western PA
    You're going to have to throw all that wood out! It'll never burn correctly now... shame.
    eatonpcat likes this.
  13. Backwoods Savage
    And after I posted the above I moved some wood into the barn. Yes, there is a lot of dust in it. They attacked some soft maple and elm. It will still heat our home.
  14. Retired Coal Miner
    Retired Coal Miner
    PA
    The particles in my pics are not as fine as this. Which points to carpenter ants.
    I'll watch closely to see if I can spot any of them. The unusual thing is the holes on the underside of the wood are much smaller than any ants I have seen so far.
  15. buZZsaw BRAD
    IME experience carpenter ants like hollow logs and will leave once the wood is dry. I used to torch them when i found during the splitting process. The only time ive found ants is when the stack isnt covered and they nest in a void or under loose bark.
  16. billb3
    I've had carpenter ants and powder post beetles in stcaks of red maple. The beetles tend to be in the tops of the stacks and the carpenter ants tend to be in the bottom of the stacks. You could always split a piece open if they are still active and see what you got. Although with the ants all it often takes is moving a piece and exposinng where the sun didn't shine.
  17. Skier76
    Skier76
    CT and SoVT
    I’ve got a few piles of dust like that in our shed in CT…
    buZZsaw BRAD likes this.
  18. MAF143
    MAF143
    North Central OH
    x2
    The hickory borers hit Honey Locust also. There are a few other borers around as well. Like others mentioned, they go away after moisture is gone. I've had them so bad in some stacks that I had to restack to get the powder out so the air could flow through the stack. I girdle my HL now so the borers are mostly gone when I drop the trees to process them. Then I don't have to deal with the pests or the powder.
