What is a smoke dragon?
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by wildwest, Oct 19, 2014.
  1. wildwest
    Wyoming high plains
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Pre-epa stoves
    wildwest likes this.
  3. firecracker_77
    firecracker_77
    IL
    Anything pre-EPA I suppose. Although, I imagine a smoke dragon will burn clean with good dry wood and a bed of coals.
    tfdchief and wildwest like this.
  4. firecracker_77
    firecracker_77
    IL
    Although some of the smoke dragons had air tubes to create a secondary burn.
    My IS heats my home and wildwest like this.
  5. wildwest
    Wyoming high plains
    Ah, like my old Schrader that I really miss....
  6. papadave
    I think generally a pre-EPA stove.
    Mine burned like crud until I got it fixed (long story) and started using real wood (another long story:rofl: :lol:) (AKA....dry).
    Once all those stars aligned, it burned fairly clean.
    Now that I have the 30, ......no comparison.
  7. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Smoke-Dragon= Majority of Pre-EPA stoves
    Usually a steel or cast box that held fire. A simple baffle was used in some models, an attempt to re-direct some of the flame from going straight up the flue pipe. Fisher stoves, my old Timberline, many others, they all qualify for -smoke dragon- status.
  8. wildwest
    Wyoming high plains
    Thanks, I googled after you used that term last week but it only brought up non woodstove things.... PS, I miss my old smoke dragon, it was so reliable. I don't even recall a baffle after sweeping many times over the years.
  9. Beetle-Kill
    Beetle-Kill
    I hear you. My Timberline, especially after I modd'ed it for secondary air, was a heating beast. 10-12 hrs. per load, but that stove was an "all or nothing" deal. It was finicky on air adjustments, and running good, flue temps. were 900+, I didn't like that.
    I miss it about 6 weeks during the winter, after that, the BKK rules.
    firecracker_77 and wildwest like this.
  10. chris
    chris
    SE WI
    A term applied to most wood stoves prior to the application of particle limits of exhaust as defined by the EPA, most outdoor boilers still are smoke dragons. In all fairness though an awful lot has to do with practices of the users as well - cut and split today- burn tommorow group. As noted above if you got the temps high enough pretty clean- just before a flue fire erupts, which of course did save having to clean the flue if it was still standing ( and the building it was attached to).
  11. oldspark
    oldspark
    NW Iowa
    A stove run by an idiot.
    Dougr6, WeldrDave, CTYank and 2 others like this.
  12. firecracker_77
    firecracker_77
    IL
    I think you just described my stove. :rofl: :lol:
  13. Beetle-Kill
    Beetle-Kill
    My BKK is not a "smoke dragon"....wait..what ?
  14. lukem
    My BBK is pre EPA and smokes like a coal locomotive on 3 year seasoned wood. But it makes heat...and lots of it...for up to 18 hours.
    splitoak likes this.
  15. oldspark
    oldspark
    NW Iowa
    Now that surprises me, do you monitor your flue temps, my Nashua does not smoke much at all after start up and the flue temps are warmed up in the normal range.
  16. tfdchief
    tfdchief
    Tuscola, IL
    Really? I must be an idiot then. Oh I have both EPA and Smoke Dragon, Does that make me 1/2 idiot?
    WeldrDave and wildwest like this.
  17. oldspark
    oldspark
    NW Iowa
    Not sure you understood the intent on the post, a smoke dragon is the result of poor burning practices, wet wood and or choking the stove down too far.
    You can have a EPA stove and make it a smoke dragon using poor techniques.
    I love the old stoves and still burn one in the shop.
    Pallet Pete, WeldrDave and tfdchief like this.
  18. papadave
    oldspark, I have to somewhat disagree.
    I had very dry firewood before getting rid of my Ashley, and made sure I let it burn hot enough, yet it still smoked.
    It just wasn't meant or designed to burn all the gases like the newer stoves.
    That said, there were plenty of times I had nothing but a heat sig coming out of the flue.
    With the new stove and a cold start, I'll still get smoke until things get crankin'. Doesn't usually take more than just a few minutes though.
    I don't believe any of that makes me an idiot.
    Were you an idiot when you had so many problems with the Summit? I think not.
    dutch likes this.
  19. lukem
    I don't monitor flue temps. It smokes pretty good for the first 30-45 minutes after startup...only a little after that...and by halfway thru the burn there is 0 visible smoke. That's with a full load.
    If I toss on a couple splits I can get near 0 smoke for the entire burn cycle, but I'd much rather load it every 12 - 18 hours even though I know I'm using more wood in the process.
  20. WeldrDave
    I have a Smoke Dragon but it don't smoke! WW, A few mentioned Pre-EPA and that is correct! Basicly "any" stove that was not directly regulated or fall under the EPA standards of wood or coal burning. Oldspark made a "great" point about you can make anystove a smoke dragon by improper burning habits! My old Fishers are considered "smoke dragons" but because of baffling and "ONLY" using seasoned wood, when I'm at 300* flue temp, you will "never" see smoke out of my chimney. Even at around 200* you can barely tell I have a fire lit. :cool::)
    Pallet Pete, oldspark and wildwest like this.
