What did I get at the dump? Mystery wood
Discussion in 'The Wood Pile' started by saewoody, Nov 16, 2017.
  1. saewoody
    saewoody
    Central CT
    I went to the dump this weekend to get rid of some yard waste, etc. and there was a nice pile of wood that someone had dumped. It had no bark on most of it and looked like it may have been standing dead, so I figured I would scoop it up because all I would need to do is split it; and with some luck maybe it would be dry enough to burn this winter (I already got a black cherry and an apple in that condition that kept my house warm the last 2-3 weeks!)
    When I split the 16-18” rounds they measured at 35% mc, so I wasn’t going to be able to burn it now. Based on the fact that there was nearly no bark, the high moisture content for what looked to be a very dead tree, and the strong, pungent smell when split, I thought maybe it could be some sort of oak that I am unfamiliar with. A few of the smaller pieces had some bark on them still, but it seems to be a fairly thick bark. It looks similar to a locust bark maybe? But I’ve never split anything with this particular grain before. Thoughts? Thanks in advance.
    IMG_5719.JPG IMG_5717.JPG IMG_5720.JPG IMG_5721.JPG IMG_5722.JPG IMG_5723.JPG
  2. Horkn
    I think you're right on the black locust.
  3. saewoody
    saewoody
    Central CT
    Thanks for the response. I don’t believe I’ve ever dealt with black locust before. Hopefully a few others will chime in as well and we will see if there is a consensus.
  4. amateur cutter
  5. saewoody
    saewoody
    Central CT
    Any ideas for drying time for locust as compared to other hardwoods? I stacked with a load of oak, figuring that whatever wood it was it would definitely be seasoned by the time the oak is.
    Backwoods Savage and gboutdoors like this.
  6. Scotty Overkill
    I'm not so sure that's black locust.....the bark looks right, but the wood screams Siberian elm.....
  7. saewoody
    saewoody
    Central CT
    I’ll see if I can find a split from a larger round.
  8. Jon_E
    Jon_E
    Southwestern Vermont
    No way that's black locust. BL is yellow inside, and the bark is wrong. I agree with Scotty Overkill that it's some kind of elm.
  9. concretegrazer
    concretegrazer
    Southwest MO
    Got a picture of the inside of the bark?
  10. saewoody
    saewoody
    Central CT
    Here’s a few bigger pieces. I know elm can be smelly. Is that also true of locust? Also, the elm I tend to split appears a lot less stringy because I have a kinetic splitter. When I used to use a hydraulic the elm would appear very stringy.
    Eric VW and NH mountain man like this.
  11. Locust Post
    My thought would be bur oak
    Eric VW, FatBoy85 and NH mountain man like this.
  12. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Butternut?
    Gary
    Eric VW likes this.
  13. saewoody
    saewoody
    Central CT
    Oh man! We went from 1 to 4 possibilities
  14. EnglishBob
    EnglishBob
    Upstate NY
    15......................Red oak
    Eric VW likes this.
  15. JCMC
    JCMC
    Just outside of Shushan, NY
    Looks like what We called Rock Oak splits relatively easy good heat.
  16. saewoody
    saewoody
    Central CT
    The first couple pics show some bark, but they are smaller diameter branches. The larger rounds had no bark left on them.
    Eric VW likes this.
  17. saewoody
    saewoody
    Central CT
    I thought it looked a little “oakish” when I first split it open. But certainly not the same as the standard red and white oak I have dealt with before.
  18. Valleyman
    Valleyman
    CONNECTICUT
    Nice cache, nonetheless ! Ill be curious to know when you get a positive ID. I was thinking a type of oak. Apple and Black cherry on your last find- you've got a great dump resource!
  19. stuckinthemuck
    stuckinthemuck
    +1 for red oak.
    Eric VW likes this.
  20. NH mountain man
    NH mountain man
    WMNF N.H.
    I agree, I just split a bunch of black Locust 3 days ago. There is no mistaking the yellow greenish wood. I'm not seeing that at all. The end grain does like like Oak, but not any I know.
    Eric VW, saewoody and FatBoy85 like this.
