Well I decided to make a pickaroon
Discussion in 'Axes, Mauls, and Hand Saws' started by RParrotte, Mar 3, 2015.
  1. RParrotte
    RParrotte
    Saranac, NY
    1" sch 40 aluminum pipe 36" long. 1*1/4" sch 40 for a sleeve at the top to add strength. 1/2"x6" threaded rod for the pick. And a little hockey tape for grip. image.jpg image.jpg image.jpg
  2. Eric VW
    Lookin' sweet, RParrotte!
    So what's your opinion on how it handles the wood? I'm sure the light weight helps the swing... Any vibration in that aluminum?
    Eric VW
    papadave likes this.
  3. HDRock
    Nice job, how you like it ?
  4. RParrotte
    RParrotte
    Saranac, NY
    I haven't tried it out yet. Just stuck it in a split in the basement for the picture. I'm going to try it out today after work.
  5. HDRock
    If the threaded rod ends up bending on ya, you can heat it up and Quench it to harden it , or get an grade 8 bolt , that's what I used
    RParrotte, splitoak and papadave like this.
  6. jetjr
    jetjr
    Pa/Md line
    20150302_111723.jpg I made one myself a little while back.
    milleo, RParrotte, Chvymn99 and 6 others like this.
  7. splitoak
    splitoak
    jefferson co wv
    I have one too...they are a very handy tool:thumbs:...
  8. Chvymn99
    Can I get some better pics? :yes: Please.
    RParrotte : So how is that working?
  9. jetjr
    jetjr
    Pa/Md line
    20150306_144104.jpg 20150306_144055.jpg 20150302_111733.jpg nothing fancy made the whole thing with a 4.5" grinder and cut off wheel.
    milleo, Chvymn99, RParrotte and 2 others like this.
  10. RParrotte
    RParrotte
    Saranac, NY
    It works pretty good. I need to do some work on it tho. I need to tig weld the sleeve to the handle. Then I need to do some work to the pick. Even with the nuts tightened right down, they loosened and it would spin on me. I have a couple of ideas as to what I might do.
    Chvymn99 and HDRock like this.
  11. HDRock
    m
    I used nylock nuts, but Sounds like you got it covered
  12. prell 73
    prell 73
    ia
    Nicely done .
  13. Chvymn99
    Well I finally got around to making my prototype. This one will be my splitting one.
    tuneighty, Deacon and Eric VW like this.
  14. Eric VW
    Pretty snazzy fab job, Chvymn99, say you'll use for splitting? I know whatcha mean.....:yes:
    Chvymn99 likes this.
  15. prell 73
    prell 73
    ia
    Looks good
  16. Chvymn99
    Like when I'm splitting to lengthen my arm reach. Its a bit shorter and a smaller tip than the one that I'll be making for my regular one. But I just wanted something to see if it would work.
  17. Eric VW
    Week, we can all see it just a' restin on that round- did you stick it into anything?
    Tell, tell.....
  18. Chvymn99
    Yes, just a few. It did alright on my ash and oak. But my Honey Locust it just bounced off. The one that jetjr and the one that Brian had shown. Had more weight on the ends, plus a sharper point than what mine does. Probably will be added on my next one...
    Eric VW likes this.
  19. Eric VW
    Nice report Chevy, thank you. I imagine when I get my "sawn twiced in half" ax head hogged down to spec, I'll be posting too.
  20. bogydave
    Looks like a well made one :yes:
    Made one a few years back.
    Now it has some pink duct tape on it so I can find it. Use it a lot.
    Eric VW and Chvymn99 like this.
