Welding Chainsaws.
Discussion in 'Chainsaws and Power Equipment' started by Mag Craft, May 24, 2017.
  1. Mag Craft
    Mag Craft
    South East Wyoming
    I have never posted any of this here before. I used to do some welding on broken pieces of chainsaws. Sometimes it was on hard to find parts and sometimes it was just to save money.
    This was a Poulan 8500 crank case that had been cut at one time for a bow saw and had been broken by a thrown chain. IMG_1535.JPG IMG_1536.JPG 8500 after.JPG IMG_1539.JPG
  2. Mag Craft
    Mag Craft
    South East Wyoming
    This here is a Poulan 3700 Handle that was broken.
  3. Mag Craft
    Mag Craft
    South East Wyoming
    Poulan Tim Allen 3750 that had been cut for a bow saw. Why I do not know but someone did it at one time.
  4. stuckinthemuck
    stuckinthemuck
    What kind of material is it? What kind of contraption are you using to weld with?
    Hinerman and blacksmith like this.
  5. Mag Craft
    Mag Craft
    South East Wyoming
    I have a lot more that I have done as examples over the years but you get the idea that almost any of the Mag on these saws can be repaired. There does come a point though on some parts that are better off replaced only because of the time it takes for the welding and shaping.
  6. stuckinthemuck
    stuckinthemuck
  7. Mag Craft
    Mag Craft
    South East Wyoming
    Miller Tig welder is the contraption and chainsaws are usually cast magnesium. The rod is AZ92A.
  8. Mag Craft
    Mag Craft
    South East Wyoming
    Your to fast for me stuckinthemuck.
  9. stuckinthemuck
    stuckinthemuck
    Looks good. Thanks for sharing. I'm one who prefers to repair rather than replace. Just seems like a waste to throw some stuff away...
  10. Mag Craft
    Mag Craft
    South East Wyoming
    Just one more set of pictures. This was on a Homelite that was scarce and the owner had asked if I would weld it.
  11. cnice_37
    cnice_37
    username checks out! That is some good looking work.
  12. Eric VW
    Awesome work and thanks for sharing Mag Craft :thumbs::yes::)
  13. Mag Craft
    Mag Craft
    South East Wyoming
    Here is a pic of the Tim Allen 3750 the one I showed being welded up from a bow saw. This was out cutting some firewood. Because I split the case to weld it so I replaced the bearings, and the seals at the same time. I also found a new top cover for it too. The saw is 60cc and it turned out great.
  14. Mag Craft
    Mag Craft
    South East Wyoming
    Thanks Eric. I think you might have seen some of those pics before.
  15. blacksmith
    blacksmith
    central Pa
    Beautiful work Mag Craft that definitely takes some skill!:thumbs::dex:
  16. Boomstick
    Boomstick Banned
    Saratoga county ny
    Any post weld heat treatment?
  17. Eric VW
    Maybe, but I don't recall them... was probably a few sleeps ago:sleeping:
    Even tho it would be unnecessary, I've thought about the possibility of adding 2 bosses to the clutch cover of my 445 for mounting an outer bucking spike. Doable?:)
    (Hope I didn't ask that before?):whistle:
    ChipsFlyin, blacksmith and Mag Craft like this.
  18. Mag Craft
    Mag Craft
    South East Wyoming
    Nope. I never pre heat and or post heat the item I am welding on to prevent cracking. Most of this stuff is pretty thin and have never really had a problem.
    I will put out a disclaimer though. I am not a professional welder and have taught my self to weld on magnesium and on chainsaw parts to be specific. So it be might recommended professionally to preheat or post heat, I just do not do it.
  19. Mag Craft
    Mag Craft
    South East Wyoming
    I think I would make a spike that fits the bar studs and when you tighten down the nuts it holds it in place. What is the clutch cover on a 445 made from. Is it the same as a 455 rancher.
    If the clutch cover is mag then yes it is doable.
  20. Eric VW
    I would guess it's magnesium, and there's only one bar nut so not sure that type of fastening would work?
    blacksmith likes this.
