Welch plug sealant
Discussion in 'Chainsaws and Power Equipment' started by 94BULLITT, Oct 28, 2017.
  1. 94BULLITT
    94BULLITT
    Frederick County, VA
    What are you guys using for Welch plug sealant? I've tried clear nail polish, which lasted a while then blue thread locker which lasted a day. I've heard seal all is good and I've used it before for other things and it worked good. I know seal all is supposed to be gas resistant.
    Horkn and cus_deluxe like this.
  2. Hoggwood
    Hoggwood
    Southern BC
    No sealant is required. I would not be putting anything that runs the risk of dissolving and getting into the idle ports and/or the high speed nozzle/check.
  3. 94BULLITT
    94BULLITT
    The Welch plug is leaking though.
    Horkn likes this.
  4. Scotty Overkill
    Hmmmm......I never used sealant either
  5. Horkn
    That's odd though, they typically don't need any sealant. RTV would be one of my only choices.
    94BULLITT and The Wood Wolverine like this.
  6. The Wood Wolverine
    Lol!
    I've never used any sealant. Get a replacement and make sure you expand it fully when you "punch" it in.
    p61 western, Horkn and huskihl like this.
  7. brenndatomu
    Yeah, just try to pucky it up with Seal All...can always replace it if that doesn't work, or that is too redneck of a repair...
    p61 western, Horkn and 94BULLITT like this.
  8. The Wood Wolverine
  9. 94BULLITT
    94BULLITT
    I'll look and see if I have another carb kit for it. If not I'll use fingernail polish til I order some. Lowes and Home Depot did not have seal all.
    Horkn likes this.
  10. brenndatomu
    Around here Ace Hardware has it...
    huskihl, Horkn and 94BULLITT like this.
  11. 94BULLITT
    94BULLITT
    After thinking about it I think I got it at true value before. I bet ace has it too.
    Horkn likes this.
  12. dall
    dall
    West Virginia
    The ethanol eats the nail polish guys used before like some have said try a new Welch plug it should be flat when installed
  13. 94BULLITT
    94BULLITT
    The welch plug is seated good but for some reason it is leaking.
  14. dall
    dall
    West Virginia
    may be a defective one and a little too small
  15. 94BULLITT
    94BULLITT
    I'm thinking there is something wrong with the welch plug.
    huskihl and dall like this.
  16. The Wood Wolverine
    Shy knees?
    huskihl likes this.
  17. 94BULLITT
    94BULLITT
    Si
    The Wood Wolverine and huskihl like this.
  18. 94BULLITT
    94BULLITT
    I don't have a carb kit for it.
    Here is what it looks like.
    I put clear nail polish on it for a temporary fix.
  19. huskihl
    huskihl
    I've saved them before. Take a punch and lightly tap the high spots down until it loosens up. Once it's out, re-form the crown in it and try it again.
    Fwiw, when I used nail polish, I used it on the edges and not on top.
    The Wood Wolverine and 94BULLITT like this.
  20. 94BULLITT
    94BULLITT
    It is running now. If I take it out and damage it I'll be up the creek. I put the nail polish around the edge. The crazy thing is the blue thread locker did not last anytime and Stihl recommends that or at least they used too.
    brenndatomu and huskihl like this.
