We All Have Our Hang-ups in Life
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Nov 25, 2023.
  1. buZZsaw BRAD
    Not one of my proudest moments as a feller!:emb: 22" DBH red maple...one of several im taking down (thread to follow soon) went awry and got hung up. It was aimed to the edge of the grass/woods line. (see pic #2) I mustve had an ADD moment and sliced through the hinge and lost it. :picard: Had a couple wood wedges tapped into the back cut. Shouldve stopped and worked it that way. Hindsight always 20/20. Bucked a round to get it off the stump then a 4' chunk and its stuck. No cant hook with me to try and roll it. Disgusted,:hair: i walked away as i need to hack down a pricker patch to keep working it. Ill bring the cant tomorrow and see what i can do. No way to winch or pull it out as the yard is too squishy. IMG_4316.JPG IMG_4317.JPG IMG_4318.JPG IMG_4319.JPG
  2. Deererainman
    Deererainman
    Union City Ky
    Hate to hit the "like" button on this. It's pretty tricky to cut a section out like you did. Is there anyway you can pull from the stump with a come-along or something?
  3. buZZsaw BRAD
    I was gonna leave it like that and try rolling with the cant hook tomorrow...a technique which has worked for me in the past. (thanks to imwiley1 for this tidbit) I did get a round then a 4' chunk cut off. The 400 did get bound up and i removed the powerhead from the bar then used a sledge and wedge to snap the chunk free.
    Ill try rolling then section it down if that doesnt work. I shouldve had a 25" bar for felling as the tree was bigger than it looked.
  4. Deererainman
    Deererainman
    Union City Ky
    Been in similar situations like that, but I was able to use a tractor or truck to get me out of a pinch. Be careful with it.
    RCBS, T.Jeff Veal, jo191145 and 7 others like this.
  5. buZZsaw BRAD
    After rethinking and looking at the pic i may give that a try. Going to dig the come a long out now
  6. Theashhole
    Theashhole
    Osceola, In
    Goodluck and be careful! That looks a bit shifty!
  7. buZZsaw BRAD
    Got the come a long just wish i had some chains. Not something i use often
  8. Chud
    Chud
    NC
    Do you have a rope? Tie to tree, extend out come a long, make a loop in the rope. You will also need a strap to hook up come a long to another tree.
    Does BuzzSaw have a block, sling and 200’ rope? I’d surely help you out if I was not so far away.
  9. buZZsaw BRAD
    Dont know. Ill have to ask.
    The hung up tree can only fall to the left of the tree its snagged on/in so i have that going for me. If i can pull the bottom to the right the top will go left. This may be more fun that i thought.
    Appreciate the offer my friend. :handshake:
  10. jrider
    jrider
    With some luck, it will be on the ground when you get there tomorrow.
  11. buZZsaw BRAD
    Thanks for the positive input, but im not that lucky! :confused: :picard:
  12. Erik B
    Erik B
    Western Wisconsin
    Towing straps work as well.
  13. Locust Post
    Harbor freight has tow straps pretty cheap
  14. FarmerJ
    FarmerJ
    Minnesota
    get a tow strap or a tree saver from harbor freight with soft shackles.
    much safer.
  15. Zack323
    Zack323
    Douglas, WY
    Were you showing off with your 500i with that wedge you cut out?! I run into this a lot in the National Forest. Once it hangs up, one thing I've tried is cutting half the hinge off on the side I want it to roll towards. At times with enough weight, it will roll it out of the hang. Otherwise, I start cutting up the base and letting it slide down. If you can cut at 30-45 degree angle, it sticks into the ground as you cut lengths off.
    I also bought a cheap braided winch rope on Amazon for $80, 100 ft rope.
  16. Erik B
    Erik B
    Western Wisconsin
    FarmerJ What is a soft shackle? I have a number of different size shackles but I have never heard of a soft one.:handshake:
  17. Zack323
    Zack323
    Douglas, WY
    :p
  18. buZZsaw BRAD
    Thats the MS400. Humbolt notch. Shouldve had the 500 with a 25 or 28" bar for the felling. Couple of the other trees are the same size. Lesson learned here.
    Edit, no pics of saw but was the 400
  19. Dok440
    Dok440
    NorCal
    Here's to hoping it is on the ground tomorrow. Those are scary. I prefer snatch straps and keeping my distance from the whole thing. A couple tugs and hopefully it will be on the ground. Be safe!
  20. Zack323
    Zack323
    Douglas, WY
    That tree would have been great for milling, lots of Ambrosia streaks!
