Want square chain with a round grinder?
Discussion in 'Chainsaws and Power Equipment' started by The Wood Wolverine, Oct 7, 2022.
  1. The Wood Wolverine
    Looks like a guy on AS is making it happen.
  2. The Wood Wolverine
    Not yet available but it looks pretty good to me. I think a consistently dressed wheel will be the biggest challenge.
    Square Jig
  3. KSPlainsman
    KSPlainsman
    Kansas
    Looks interesting. I wonder what the cost will be. Does it connect to a Tecomec style grinder?
    Horkn, John D, T.Jeff Veal and 2 others like this.
  4. Eric Wanderweg
    I likee. As a toolmaker/machinist, I think I need to make one of these :)
    brenndatomu, Horkn, John D and 3 others like this.
  5. JimBear
    JimBear
    I believe you are correct, a person could end up with a bunch of different type of cutters per loop.
    brenndatomu, Horkn, John D and 4 others like this.
  6. The Wood Wolverine
    Talk of $300 range. And it fits Oregon grinders so all their basic copies should be good (Tecomec, Efco etc).
    Knowing the end goal and what a proper square tooth looks like will be important too. As a tooth gets ground back with time, positioning it will be interesting because there is no stop or guide for it to set against, like most grinders have. Maybe I’m missing something there.
    brenndatomu, Horkn, John D and 2 others like this.
  7. The Wood Wolverine
  8. buzz-saw
    buzz-saw
    Ct.
    x2 on that.
  9. KSPlainsman
    KSPlainsman
    Kansas
    It will be interesting to see how it all shakes out as people get them in their hands. I have never run square ground chain, but if it was something I wanted to do much of, I'd just find a square grinder, but I like that this could be a viable option for people.
  10. The Wood Wolverine
    New you’re looking at 1,500-1,700 USD. Used is pretty high as well, if you can find one.
  11. KSPlainsman
    KSPlainsman
    Kansas
    I knew new ones were pretty high, but I didn't realize used ones were so scarce and you're right, they're pretty high too. I guess I was a bit too optimistic thinking a used one could maybe be found for 500 ish.
  12. John D
    John D
    Syracuse ny
    You are right thou if it was something we wanted to get into I could see spending the money on a new grinder
    Most are of us are firewood cutters and some are tree companies
    I personally will take a round ground chain over any for I can hand file and I have the electric grinder to sharpen them
    Also where I live round chains are more available
    If I grew up where squares chains where the go to I obviously would be running a square chain
    brenndatomu, buZZsaw BRAD and Horkn like this.
  13. Eric Wanderweg
    Once you try it, it’s a slippery slope… I recommend sticking to round unless you’re okay with going down a rabbit hole ;)
    Oregon 72CJ (3/8
  14. buZZsaw BRAD
    Kind of a dumb question from a non metal worker/fabricator.
    I noticed the edge of the chain he ground in the OP video turned bluish/purple when he finished. Is the hardness lost on the tooth?
    brenndatomu and John D like this.
  15. Eric Wanderweg
    Yes… you definitely don’t want to heat it up to the point where it’s turning colors. That means the metal became annealed (softer) Small/quick taps with the grinding wheel with pauses in between is good practice.
  16. John D
    John D
    Syracuse ny
    I will ask you Eric
    3/8 chisel chain
    Does round hold an edge longer/better than square ground
    Same saw same size bar round vs square how much faster do you really feel it is
  17. Eric Wanderweg
    IME square holds an edge longer than round. It’s also a lot smoother in the cut. It’s no doubt faster too, but I don’t know by how much, numbers wise. What I can tell you for sure is I’ve had 3/8 Oregon full chisel chain on my old Stihl, bucking oak. I started with a square filed chain, made probably a couple dozen cuts before dulling it in the dirt. Then I switched to a brand new Oregon round ground factory chain (same chain minus the square filing) and it was cutting significantly slower than the square was when it was sharp. Not quite like 50% slower, but it was a night and day difference.
  18. John D
    John D
    Syracuse ny
    That is exactly the way I wanted the answer.
    Do you think if o bought a square chain grinder that I could make my round chains square or at that point are you better just buying new chains
    Just putting it out there
    buZZsaw BRAD likes this.
  19. Eric Wanderweg
    It’s easy enough to convert round to square. I only do it with chains that have at least 50% of their life left though. If they’re already filed back close to the tooth limit it’s kind of a lost cause.
    John D likes this.
  20. Eric Wanderweg
    The first chain I converted was rocked pretty bad anyway and needed to be filed back considerably, so it was a good guinea pig for me. I start by rough filing with a flat file, squaring the tooth up to get most of the material out of the way. Then I switch to the bevel file. I’m going to use this same approach with the grinder.
    John D likes this.
