Very good draft today stove is trying to take off
Discussion in 'Modern EPA Stoves and Fireplaces' started by HDRock, Dec 12, 2013.
  1. HDRock
    Temp is 17, Wind is 15 to 23mph
    Loaded it three quarters full with oak and ash uglys
    Usually I don't turn the air all the way down, Today I have to, and I am glad I have a blower.
    With the blower on medium is keeping it down to 740 Stove top.
    It has been rolling for an hour now
  2. bogydave
    Same weather we're having now
    17°, wind 15 NNW , overcast
    No Oak though, just birch :(
    splitoak likes this.
  3. HDRock
    I am still learning this EPA stove, With these colder temperatures and a great draft I am having to use the blower and Having to babysit the stove An hour and a half to two hours, Is this normal ??
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    740 is hot! I'm thinking you have quite a warm house with those numbers
  5. HDRock
    Yeah its was 81, Cooling down now 78
    Chvymn99 likes this.
  6. bogydave
    it's the
    "Burning learning curve"
    Takes some time to get each system figured out.
    Weather swings are tough to adjust for.
    After a while you'll get to where you know the setting for "X" weather
    & not be tinkering with it.
    Bet you had similar issues with your old stove, just not a sensitive to minor adjustments
    & you knew that system well.
    I found it's better to burn on a little higher setting than try to tweak it down.
    I'm hitting more & more night settings near perfect after a couple years :)
    Wind stopped sometime last night, (45 mph to 10)I struck out with that one, LOL
    Huntindog1, tfdchief and HDRock like this.
  7. Backwoods Savage
    NO.
    splitoak and NortheastAl like this.
  8. Locust Post
    Each stove is different but maybe you are letting the load get going too much before dialing the air down. Just a thought, I'm not there.
  9. HDRock
    May be, I was thinking that
  10. rdust
    rdust
    SE, Michigan
    You know your birch is like our Oak! ;)
  11. rdust
    rdust
    SE, Michigan
    For his stove it's close to typical! When I had my Lopi Endeavor I would never leave it without it burning for an hour or so. It liked to head for the moon when it was teens or colder. The stove was basically uncontrollable with my chimney when it was cold, it's one of the big reasons it's no longer on my hearth.
    splitoak, NortheastAl and HDRock like this.
  12. HDRock
    Well do you think the oak with an inch or so of Dry punk on it is Contributing
  13. NortheastAl
    NortheastAl
    Putnam County NY
    My Endeavor tried that tonight at 18° outside temps and a fully loaded firebox. The top got up to 700. It is a learning curve, and once the heating season is here in earnest, then you'll pretty much have it down pat. I can say that throttling it back too late will get you close to a runaway on a full box almost every time. That's what did it to me tonight.
    I babysat it a few times last year, which was my first year burning wood. I think there will be much less of that this year.
  14. jeff_t
    jeff_t
    SE MI
    Threads like this make me appreciate my stove even more.
    splitoak and Backwoods Savage like this.
  15. Backwoods Savage
    For good reason it is no longer on your hearth. But one can not say this is typical for epa stoves in general. Of course there are exceptions to every rule.
  16. Backwoods Savage
    NO. That dry punk will not affect it or if it does, it would tend to slow it down a bit at the start.
  17. HDRock
    Thanks for the tip
    Dialing it down sooner now, Sneaking up on it rather than blasting it and then bringing it down, And it is working very well.
  18. HDRock
    This stove does like to run hot but I think mostly The problem was the operator :)
    Just part of the learning curve for my first EPA stove
  19. Locust Post
    Good to hear HD.....I'm still learning a few things about mine too, sure different than the old stove. I like it though.
  20. Locust Post
    Don't know the Lopi's is that a cat or tube stove ?
