Unwanted In ground swimming pool:(
Discussion in 'Everything Else (off topic)' started by Biddleman, Jul 26, 2023.
  1. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Woke up yesterday to no water. After checking pressure tank, power, pump wiring. I thought the pump was on the way out or junk. Was on the way back upstairs and saw this puddle. Which wasn't there when I came down to the basement. Hmmmm....
    Switched the breaker to the well pump back on and came out to look. Yup, water coming up from the ground. :doh:
    My backhoe dug the trench out while I was at work.
    2 well pipes in the trench. Whoever put the new one in just followed the old one. 20230725_150850.jpg
    Found the leak and marked it. Off to the big box store and got what I needed. The pipe was on top of a jagged rock. I think it got sliced when they put it in and over time slight friction and the water pressure did it in.
    After going to the store got the problem fixed.
    Just an average Tuesday in PA. :D
  2. The Wood Wolverine
    Hard to "like" that but glad it's fixed.
  3. brenndatomu
    You are probably right, it happens on city water mains too...best practice is to lay the pipe in a bed of sand, then cover it with sand before putting dirt back in the hole.
    That polyethylene does get brittle/weak over time too though...doesn't last forever.
    Glad to hear you are back up n running with minimal downtime and expense though...other than maybe the cost of fueling your backhoe back up :D
  4. Locust Post
    Glad it got worked out and you had 'chinery to work with......:D
  5. Canadian border VT
    ‘Chinery makes that job mucho betterer
    Chaz, fuelrod, Chvymn99 and 3 others like this.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    Glad you caught it and were able to fix it but, How'd you get your backhoe to dig a hole all by itself?
    Chaz, eatonpcat, Chvymn99 and 6 others like this.
  7. Biddleman
    Biddleman
    Glad you mentioned the about the sand. I thought about doing that and was going to ask about it.
    I just said backhoe, please dig that trench. And he did. :D It was good practice because he starts his job with a commercial mechanical contractor soon and they're sending him to school for plumbing.:thumbs:
  8. yooperdave
    Good quickfix.
    Could've been worse....could have been septic field related! :whistle:
  9. Canadian border VT
    That’s would be a chitty situation. been there done that
    JD Guy, Biddleman, Chvymn99 and 2 others like this.
  10. yooperdave
    Yup.....got that T-shirt, too! Twice!
