Unique corner posts for firewood shed?
Discussion in 'The Wood Pile' started by Easy Livin' 3000, Jan 5, 2019.
  1. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    I have an abundance of tulip poplar.
    I was thinking I might try something unique for the corner posts of a woodshed.
    The tulip poplar logs are too big for me to move in one piece, but if I cut them into rounds, I can manage. I'm thinking either 12 or 16".
    Then, use the rounds like round blocks, and mortar them together in a stack on top of poured footings, leveling them along the way. 8' apart. 6 in all for an 8x16 shed.
    Once the corners are up, I'm thinking 7' high, put a traditional stick frame roof on.
    Is there anything I'm missing, like perhaps the mortar won't stick to the wood?
    Ou812, gusty60, T.Jeff Veal and 7 others like this.
  2. Eric VW
    You’d probably fare much better with black Locust.
    But whatever wood you choose, this sounds interesting. :yes:
  3. Easy Livin' 3000
    Easy Livin' 3000
    I'd love to do it with BL, rot resistant as it is. Alas, none to be had!
  4. Eric VW
    Uggghhh.... none around you, or no where to source it?
  5. Easy Livin' 3000
    Easy Livin' 3000
    I could probably find some about an hour away, had a buddy who's property had tons, about 40 miles from here, but he moved. I'm in the middle of miles of suburbs.
    I have a couple of tree surgeon friends I could ask, but I'd prefer to save those chits for chips and occasional firewood.
    There's still lots of hedge around on the roads, which I'd like as much as BL, but not much is straight, and I don't know the landowners.
    The TP is right here. Much as I want, and straight as an arrow. Once covered, I think it'd last long enough.
  6. dingbat
    dingbat
    Western Northern Cackalaky
    A lot of the old barns and log cabins around here are Tulip Polar. Stuff seems to hold up just fine if you get enough roof over it. Pour your footings as far above grade and give your roof as much overhang as you can manage. It'll likely last quite a while.
    Eta: You'd definitely want some sill seal, presure treated, or the like between your footings and the poplar
  7. Easy Livin' 3000
    Easy Livin' 3000
    There's tp in my barn, bark still on, probably at least 80 years old.
  8. brenndatomu
    As you said, I don't think the mortar will hold long term...Gorilla wood glue maybe? Would be more cost effective to go get some treated posts though...
  9. Easy Livin' 3000
    Easy Livin' 3000
    Glue is expensive, you are right about that.
    Perhaps mortar and some pins.
    I'm thinking the expansion/contraction and moisture cycle in the wood would be bad for the mortar. I'm mostly looking for the leveling.
  10. Warner
    Warner
    Why cut the log then glue it back togeather? Just use the log un cut?
    I just reread the op. I’d try to find some smaller dia. Logs that I could handle.
  11. Warner
    Warner
    I believe I have seen some pics of DaveGunter s wood shed made of logs. I think his is pretty slick!
  12. brenndatomu
    Just what I though too...get a case of beer and some pizza...call a few buds over...then work smart not hard, you can stand them logs up whole. :yes: (beer after logs are moved ;))
    Yes
  13. Easy Livin' 3000
    Easy Livin' 3000
    This is all very logical. Problem would be keeping them out of the beer before we got started. I'd be guilty as well, and here we are 5 years in, still using tarps!
  14. Slocum
    Slocum
    North Central Indiana
    Poplar will out last you as long as it’s dry.
  15. BigPapi
    BigPapi
    The hills of Western MA
    Maybe a few long spikes as used in log cabin construction to keep everything straight? Ideally I'd agree with the above that the whole log would be much stronger laterally. Maybe you can do a rough milling on each log to make a 6x6 or so beam that would be easier to raise into position?
    either way, looking forward to photographic documentation of the project. ;)
  16. Easy Livin' 3000
    Easy Livin' 3000
    The rough milling would be my favorite outcome. My saw has a 20" bar, and I think I could part with the dough for a chainsaw mill. 28' of milling per post, x 6 posts- 168' total of milling. My old husky 455 might not like that.
  17. DaveGunter
    DaveGunter
    Sounds like he's dealing with a lot bigger diameter logs. Mine were 6-8" max. Here's the thread in case you are interested ED 3000
    finally finished the woodshed
  18. Pallet Pete
    Pallet Pete Moderator
    Ovid
    The problem with concrete and untreated wood is moister. The water will be trapped in the post and rot it out very fast without an escape route. You might find even with a good gravel drainage bed under the post and concrete that they will still rot away and they will be caused by the concrete sweating water through it into the post as well. Concrete is pours and lets water in pretty easily. You might find something simply like dipping the part that goes into the concrete in rubberized undercoating first then cutting the bottom 1/2" off and poring gravel under the post before concrete to be effective at letting them drain but not rot. I have done that and had success before.
  19. Easy Livin' 3000
    Easy Livin' 3000
    Thanks Dave!
    I would love to do one exactly like yours, but I used up almost all of my logs of similar diameter building raised beds for my garden 5 years ago. While I loved the outcome in the garden, with more forsight, I'd have saved at least 13 of them for the shed.
    We are on about 5 acres here, and the trees I have left of that size are either crooked, or birch, which rots way to quickly for this application.
    I bought landscape timbers for the job, but they all ended up as racks.
  20. Eric VW
    Ya killin’ me Pete.....:picard:
    :whistle:
    Felter, Ou812, T.Jeff Veal and 4 others like this.
