Ultimate mill machine video...
Discussion in 'The Wood Pile' started by Stinny, Mar 2, 2017.
  1. Stinny
    Thought the log mill guys might like this vid...
    milleo, Gasifier, Eric VW and 8 others like this.
  2. Hinerman
    Hinerman
    NE Oklahoma
    No telling what that set up costs. And for what it costs, I would want the operator to be on the opposite side of where the dust is blowing out.
  3. ReelFaster
    ReelFaster
    S.Jersey
    Pretty bad a$$.... thanks for sharing!!
    Backwoods Savage and Stinny like this.
  4. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I wonder why it doesn't cut in both directions. Seems like a lot of waisted time in the return.
  5. FatBoy85
    FatBoy85
    Washington State
    I was thinking the same thing.
  6. Mag Craft
    Mag Craft
    South East Wyoming
    That is quite the machine.
  7. Backwoods Savage
    Pretty much all band saws I've seen have teeth on one side only. It would take some fancy work to make the machine swivel around and the time it takes would probably be about the same as bringing it back.
    Perhaps the bigger problem with these types of mills is that the saw has to come back and clear before someone can remove the slab or lumber so the sawyer has to wait while it is being removed. That is hard work removing it too. If the band saw runs vertically (there it is again) then the slab can fall off onto a conveyer and not have to be lifted off and the sawyer does not have to stop to wait which saves a lot of time.
  8. FatBoy85
    FatBoy85
    Washington State
    Well seeing how most saws could be interchangable (directionally) i Would have thought a machine this loaded up would have just rotated its saw so it would have flipped over 180 via a simple axle gear and never had to do anything super complex.
    The part about that is that there would be two exposed cutting areas but as long as the moving part is well away from anyone and the operator is well shielded, they just have to afix a simple motor on it and there's no wasted time or energy.
  9. Ralphie Boy
    Ralphie Boy
    I was thinking along the lines of a double sided blade. No rotatong anything just hit reverse.
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    Band saw blades are supported by bearings on both sides of the blade and also behind the blade, on both sides of the cut. Having teeth on both edges would make the bearings behind the blade impossible, and without those the pressure of the cut would push the blade out of position and the teeth would be destroyed when the points hit the side guide bearings.
  11. yooperdave
    Kinda makes you wonder what the heck was used to load that log onto the mill, no?
    Backwoods Savage and FatBoy85 like this.
  12. bert the turtle
    bert the turtle
    3 feet of 4 inch rubber tubing hose clamped to the discharge would allow the operator to breathe after completing a full shift. That poor guy is going to be hacking out sawdust all night.
    Backwoods Savage and yooperdave like this.
  13. Eric VW
    Light saber. Done. :yes:
  14. Gasifier
    Cool!
  15. FatBoy85
    FatBoy85
    Washington State
    I can imagine one of those claws on a large tractor. At least for precision and control...
  16. yooperdave
    Judging from the size of that log, large is required!!
  17. FatBoy85
    FatBoy85
    Washington State
    Definitely like the mega farm equipment sorta arena.
  18. Backwoods Savage
    3 men and a boy.
    yooperdave likes this.
  19. Backwoods Savage
    They probably do that but the video looks like they just set this up for a demo so didn't bother.
