Two stroke whisperer
Discussion in 'The Wood Pile' started by mrfancyplants, Apr 4, 2022.
  1. mrfancyplants
    mrfancyplants
    South Carolina
    I am not a “two stroke whisperer”, by any means, but I had to brag that I helped a neighbor out today. His mower was starting and then kicking out after a second or two of running. He had the filter off and was messing with the carburetor. He had already replaced a fuel line. I reached over and said “try this” and it was off to the races.
    Any guesses what I did? I bet you’ll get it quick.
    Woodsnwoods, Horkn, M2theB and 4 others like this.
  2. Greenstick
    Greenstick
    Pushed the plug wire onto the plug, or turned the gas on.
  3. clemsonfor
    Does your neighbor still run a Lawn Boy mower? That's about the only two stroke mower that I can think of?:eek:.
    Could be the float had stuck and when you went to mess with it it unstuck and allowed fuel to re enter the dry carb bowl and after that it was working normal once it was broken free?
    Edit: I read this as what could I have done. I see this is a question to see if we can figure out what easy thing you did...I'm with the previous post as you knew you did something easy and we're trying to figure it out . But I'd say cut fuel on cause you said it would run then cut off so it had spark so I doubt the wife was off unless it was close and arching through the boot enough to hit a few times and stop for some reason
  4. MikeInMa
  5. mrfancyplants
    mrfancyplants
    South Carolina
    aaah, you are right, not a two stroke, because it has an oil tank. Shows how much I know.
    No correct answers yet though. Good answers but not how I got this one running. the gas was on and there was spark. Primer was priming, even dribbling out the side with the filter off.
  6. JRHAWK9
    JRHAWK9
    Wisconsin
    shut the choke off?
    clemsonfor, Horkn, M2theB and 3 others like this.
  7. buZZsaw BRAD
    Turned the choke off and im not a two stroke wonder either!
    EDIT: this stated without reading the replies.
  8. brenndatomu
    You put your hand over the intake while he cranked it?
  9. brenndatomu
    It could have an oil tank and still be a 2 stroke...its called a pre-lube system...there is a pump that pumps 2 stroke oil into the intake at a rate based on throttle position and engine speed...but I've never seen one of those in a mower...more of a motorcycle and snowmobile thing.
  10. mrfancyplants
    mrfancyplants
    South Carolina
    Choke was my first guess too, but that didn’t do it. I didn’t put my hand over the intake.
    Good hypothesis’.
    let me know and I’ll spill it.
  11. TurboDiesel
    Tapped on the carb to loosen stuck float
  12. Murphy681
    Murphy681
    North Carolina
    Turned the gas back on.
  13. TurboDiesel
    Checked the gas tank level
  14. brenndatomu
    Trickled a little gas down the intake?
    clemsonfor, Horkn, M2theB and 2 others like this.
  15. MikeInMa
    The run stop switch was in the off/stop position?
  16. LordOfTheFlies
    LordOfTheFlies
    NY
    Adjusting the idle screw?
  17. Mag Craft
    Mag Craft
    South East Wyoming
    Well, the comments you have made so far would lead me to believe there was plenty of gas if this is not so then let us know.
    That would only leave spark and compression, or it was not getting air but gas. So far too ambiguous to give an answer.
  18. Canadian border VT
    I’m with Mag Craft 3 things engine needs air fuel spark.. my first guess was choke
  19. mrfancyplants
    mrfancyplants
    South Carolina
    All very good hypotheses, but no one has nailed it yet.
    there was plenty of gas until there wasn’t. The primer was working. No adjusting of the carb required.
    I’m about ready to spill it, and my neighbor was too once I did my quick fix.
  20. Mag Craft
    Mag Craft
    South East Wyoming
    Filled up the gas tank. Otherwise it is just a guessing game because not enough info to give an educated answer.
