Truck U-Joint issues
Discussion in 'The DIY Room' started by bobdog2o02, Jun 21, 2016.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Having issues with the u joint by the rear axle... since the clutch swap I heard some weird knocking... it's the u-joint. The cups are not being pinched by the straps/clamps and the whole u joint is sliding side to side on the drive shaft yoke. Is there some kind of shim available to tighten it up or did someone use the wrong strap/clamp for a previous replacement? 2001 dodge 2500 with 24V HO cummins and nv5600 6 speed.
    Thanks guys
    Eric VW MasterMech clemsonfor TurboDiesel Horkn
    MasterMech, Eric VW and Horkn like this.
  2. brenndatomu
    No, no shims. Sounds like someone used the wrong joint for the truck
    Horkn likes this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Compared to the right ones.... the joints are right, straps appear to be the problem...
  4. Bret Hart
    Bret Hart
    Central NY
    Are there tabs sticking up in the yoke openings to stop the joint from sliding? Broke off?
    Eric VW, Horkn and Jeffrey Svoboda like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yup, the tabs on the yoke are the only thing keeping the joints from coming apart....
  6. Bret Hart
    Bret Hart
    Central NY
    I remember breaking one of the universal straps on my 2000 Cummins. Seems there were several options depending on what rear end it was built with. Dana 70 or 80 I think.
    Do you know the universal number you installed?
    Horkn likes this.
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    not off hand, I think ill be buying new straps and a new universal and do the whole shebang.... ill make sure napa knows its a dana 80....
    bushpilot, Eric VW and Horkn like this.
  8. Bret Hart
    Bret Hart
    Central NY
  9. Onepieceatatime
    Onepieceatatime
    Are the caps held in securely but the joint moves? If so I'd say your missing all your needle bearings. If I were you'd I'd take the truck to the nearest chevy dealership and trade it in Asap!
    Sent from my SM-G930T using Tapatalk
    Thor, Gary_602z and Eric VW like this.
  10. TurboDiesel
    Not much help here, Aaron.
    Eric VW, Horkn and bobdog2o02 like this.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    No, the caps are moving, if I trade it's going to be an engine swap to a ford...
  12. Onepieceatatime
    Onepieceatatime
    If it's an 80 it might be a 1410 maybe a 1350. Those are spicer numbers and I recommend Spicer joints. I do a lot of rock crawling and we blow up a lot of u joints and I'll only use Spicer stuff.
    Horkn likes this.
  13. Onepieceatatime
    Onepieceatatime
    And why would anybody engineering swap a Cummins to a Ford Motor? I'm not a Dodge fan at all but going from a Cummins to a Powerstroke (unless a 7.3) is like going from a Stihl to a Poulan.
    Thor likes this.
  14. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    No, I'll buy a dead ford and transplant my cummins power train to the ford.....
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Welcome by the way, happy to hear your input.
    Eric VW likes this.
  16. Onepieceatatime
    Onepieceatatime
    Dead Fords are easy to find. They're the best selling trucks because they need replaced the most! I'll wear my Bowtie till I die!
    Thor and basod like this.
  17. Eric VW
    bobdog2o02, I don't know the first thing about diesels and less about changing/ checking u joints.
    Get it fixed, man- you have a trip to make this weekend:thumbs:
    Horkn, TurboDiesel and bobdog2o02 like this.
  18. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    A trip to meet a special member....
    Horkn, TurboDiesel and Eric VW like this.
  19. Eric VW
    Yeah...special alright.....:rofl: :lol:
    Horkn, bobdog2o02 and TurboDiesel like this.
  20. TurboDiesel
    EXTRA special
    :D
