Tricky Hickory
Discussion in 'The Wood Pile' started by JDU, Aug 5, 2022.
  1. JDU
    JDU
    Perry County, PA
    Month ago, bad storm went through causing lots of down trees, including a big hickory at edge of yard.
    As you can see in first picture, it hung up about 10' up parallel with the ground. Too dangerous to cut like that, I just left it other than cutting some branches off as it was blocking my woods road. It came down, sort of, a week ago, so I was able to start cutting it up. One good thing as you can see, don't have far to go to my firewood processing area and stacks! Still have the tricky part to do as it is attached to the standing half of the tree. Not sure what it is going to do as I get closer to that. Any ideas on what might happen, and or how to proceed? Thanks. DSC00737.JPG DSC00806.JPG
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Carefully! Other than that I have nothing to help.
  3. Scotty Overkill
    Good stuff, gotta be careful with those kind of iffy situations. One thing you can do (we've done it ourselves many times) is shoot a rope up over a healthy branch above, butt-tie the hanger and pre-load it with some light tension, and as you cut down that hanger, the rope will keep it from getting really sketchy. Or you can do the rigging method I just described, pre-load the rope, and cut the hanger loose from the tree. Lower the hanger to the ground and commence cutting.
    Whatever you do, please be careful brother! They call situations like this one "widow makers" for a reason.....
  4. Scotty Overkill
    At some point. That tree could become a hazard. As much as you might not want to, I'd consider piecing it down while it's still healthy enough to do so. The blowout split from the felled codominant section most likely is going to cause structural issues down the road.
  5. JDU
    JDU
    Perry County, PA
    I agree. Badly splintered at split. I'm going to cut as much of the fallen section as possible and then assess the possibility of taking other 1/2 down.
  6. JiminyKicket
    JiminyKicket
    Seattle
    Thank goodness none of those beautiful stacks were harmed!
  7. The Wood Wolverine
    I'm sitting here thinking to myself, if there's enough real estate behind, a nice tub of tannerite would do the trick!
  8. Screwloose
    Screwloose
    Bottom picture.... I'd lash it securely to the tree on the right then stand on the left and start cutting off chunks.
  9. JDU
    JDU
    Perry County, PA
    I was planning on just cutting off 16" chunks until??????? Good idea. Thanks. Might be safer.
  10. jo191145
    jo191145
    Ct
    Have anything to pull it with?
    Or toss a pound of hamburger up there and maybe a bear will climb up to get it.
  11. Eckie
    Eckie
    Hahaha where's cigarsmokingzombie.....
  12. brenndatomu
    Creative! :thumbs:
  13. buZZsaw BRAD
    Mother nature provided. Good thing it didnt hit your stacks or house.
    Mark your lengths on the log. You can buck either single pieces or lengths working "uphill" Cut from the top of the log first halfway or so.(dont wait until saws jams from tension) Then cut from underneath using top of bar until cut complete and log is free. Repeat as you feel comfortable doing
  14. buZZsaw BRAD
    YES!
  15. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Looking forward to pics for sho...
    Be safe too.
    Sca
  16. JDU
    JDU
    Perry County, PA
    Tricky Hickory is down. No problems. Of course, I waited until it was 95 degrees and humid to do it! Time now for some cool air and cold drinks! :dennis: DSC08345.JPG DSC08346.JPG
  17. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Well done! Now go have a cold one!
  18. Brad M
    Brad M
    Pleasant Hope MO
    I’m a little late now but I’ve taken some like that by felling the still standing trunk at 90* perpendicular angle to the direction of the hung up portion. Still have to be extremely careful though. Glad you got it down without any trauma. Good job.
  19. buZZsaw BRAD
    Way to get it done and done safely. :thumbs: What about the piece still up there?
    JDU likes this.
  20. JDU
    JDU
    Perry County, PA
    Well, that is far as I could reach safely. I agree with Scotty Overkill, the standing 1/2 is going to deteriorate and come down, so I think I can do that and then the hanging piece will come with it. Although....if I can get my tractor close enough I might be able to rip it off. But you know how tuff and stringy hickory is.
