Trapped heat
Discussion in 'Modern EPA Stoves and Fireplaces' started by justdraftn, Sep 26, 2017.
  1. justdraftn
    justdraftn
    On the road
    I use a Lopi Revere insert. It is installed into an old
    Heatilator steel fire place box. The 6" flex pipe for the stove comes
    through a slot cut in the damper and top of the fire place box.
    The pipe is insulated and the gap around the pipe and damper is insulated.
    I have the 12" trim around the stove. I think a lot of heat is being trapped
    in that space a between the stove and fire place box.
    I'm thinking about cutting some slots or get a metal guy to cut
    some kind of design in the top piece of trim so that heat can escape into the room.
    Thoughts/comments/suggestions
    wildwest likes this.
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Do you have a good block off plate and the chimney filled with insulation, not just an insulated liner but poured full of insulation around the liner?
  3. brenndatomu
    I would bet that there is not as much heat being trapped back there as you think as long as you have the insert fan running
