Trailer fenders - help needed
Discussion in 'Chainsaws and Power Equipment' started by CtRider, Feb 27, 2017.
  1. CtRider
    CtRider
    Ct
    Hi gang
    I'm getting my grandpas old camp trailer that's been sitting at my dads for 5+ years. Tires are dry rotted but wood panels seem in decent shape. The problem is that I need to get registered and now you need fenders.
    All the fenders I can find are for small wheels, not full size tires. This is one of those trailers with an old Chevy axel and full size tires.
    I'm not much of a metal fabricator so what ideas (make or purchase) does the group have. I know photos would help...will try to get some soon.
  2. Butcher
    Butcher
    [​IMG] ???????
    jo191145, gboutdoors, Boog and 6 others like this.
  3. Warped5
    Warped5
    Northwest IN
    I was thinking the same as Butcher .... but using 55 gallon drum pieces.
  4. Woodporn
    Woodporn
    S. MA
    Northern tool sells fenders
    Sent from my Pixel using Tapatalk
  5. Woodporn
    Woodporn
    S. MA
    Or try these guys,
    Home
    gboutdoors, Eric VW and Gasifier like this.
  6. CtRider
    CtRider
    Ct
    Thanks guys I didn't see any at Northern tool for full-size tires. Butcher are those window wells you see in basement windows?
  7. chris
    chris
    SE WI
    yes they are
  8. Butcher
    Butcher
    Yes they are. They may look redneck but they work well and there are many a trailor running the roads around here with them WW's as fenders. Price is pretty cheap too compared to trailor supply places. Home made brackets needed as nesisary.
    Screwloose, gboutdoors, TBONE and 2 others like this.
  9. Gasifier
    I've never seen those used like that. Interesting. Should be strong.
    gboutdoors, Deadwood and Eric VW like this.
  10. Eric VW
    And rust resistant to boot!
    gboutdoors and Gasifier like this.
  11. Deadwood
    Deadwood
    That's actually a great idea...and cost-effective too.
    MountinMan, gboutdoors, TBONE and 2 others like this.
  12. CtRider
    CtRider
    Ct
    Great idea!
  13. amateur cutter
    Huh, never woulda thought of that. Great Idea!
  14. CtRider
    CtRider
    Ct
    I'm very impressed! I'm undecided between galvanized or plastic. Gal would be stronger but not easily painted. Both would be rust resistant. Thoughts? Price is close enough it's not a factor.
    I think the metal would fair better if a rogue split hit when loading/unloading
    gboutdoors and Eric VW like this.
  15. Deadwood
    Deadwood
    Pros: I like the fact that the window wells are replaceable cheaply. Don't need to paint them, ever. Big enough almost for a dual-axle log splitter or a log-splitter with a dually wheel config.
    Cons: Mounting flange configuration might be a little strange...So I guess modify away! Cut off existing flanges on ends? Custom brackets then or use self-tappers? Depends entirely on what you're mounting onto.
    gboutdoors likes this.
  16. Woodporn
    Woodporn
    S. MA
    I'd go galvy......just knowing what I've put my trailer through I think the plastic would have been destroyed long ago.
    How much are the window wells?
    gboutdoors and Deadwood like this.
  17. ironpony
    ironpony
    Mid Ohio
    Butcher beat me to it............they also come in heavy plastic might be an option
  18. CtRider
    CtRider
    Ct
    The best mounting option I've come across is to use gas pipe across the tops. Flanges to the trailer sides, and conduit type -u- shaped brackets to mount fenders to gas pipe.
    Hammy, Screwloose, Ashwatcher and 6 others like this.
  19. Deadwood
    Deadwood
    That's pretty cool CtRider. Thanks for sharing that pic. Got close-ups of the flange mountings, brackets and hardware used?
    gboutdoors and TBONE like this.
  20. crzybowhntr
    crzybowhntr
    WV
    Don’t overthink it too much. I`m sure that you can fashion something out of a 2x10 or 2x12 that will make the state happy. If it is just a utility trailer why not? I see wooden truck beds all the time.
    Deadwood and gboutdoors like this.
