Top-down Fire Starting?
Discussion in 'The Wood Pile' started by RichE23ACR, Nov 11, 2025.
  1. RichE23ACR
    RichE23ACR
    Hunterdon, NJ
    Hello,
    I have read and watched about people that recommend building fires upside down. This is counter intuitive to me and goes against physics. For $#¡+$ & giggles, I tried it in our Napoleon 1400 woodstove. It worked, sorta. The fire started, but was slow. The stove was very slow to start pumping out BTUs. Am I missing something?
    Thanks!
  2. Burnin Since 1991
    Burnin Since 1991
    How did you build your top down fire? I use it all the time and it works for me 95% of the time. It isn't for everyone. It helps to get the stove and chimney heated up so the draft is better. If you have a good draft, then you might not need to do it that. Tell us more about your setup, chimney etc.
  3. Backwoods Savage
    Top down is definitely slower. You do get less smoke but that is probably because of the slow burn. After all, you are only lighting the top of the wood. Some like it but I don't. It still works better to start the fire on the bottom as that way the heat and flames ignite more wood; hence the fire gets started quicker.
  4. buZZsaw BRAD
    Ive always did from the bottom and never tried the top down. Makes sense that it would warm the flue for a better draft.
  5. MikeInMa
    Husky or Stihl
    Horizontal or vertical
    Tomato tomato
    Top down, or down up
    Whatever works best for you. Personal preference.
    Me? Bottom light
  6. arizonasportsman
    arizonasportsman
    Prescott, AZ
    I've also always started fires in the stove from the bottom...but just recently been trying the top approach for the benefits of getting the chimney heated sooner. Not ready to give up on it yet, but early indications tell me I will return to my old ways.
  7. brenndatomu
    I don't care for a top down fire, but then I have no reason to need to do it that way either...
  8. The Wood Wolverine
    To me this would help warm up a cold flue.
  9. Ronaldo
    Ronaldo
    Usually top down here. Once I heard about it and gave it a go, I like it.
  10. Va Homesteader
    Va Homesteader
    Central Va
    I burn from the bottom up, this method has worked for 46 years, I've no interest in trying top-down method.
  11. Skier76
    Skier76
    CT and SoVT
    I do a modified version of this. I build it like a top down fire; Bigger splits on the bottom, kindling & a starter on top. Then a put a fire starter between the two bigger splits. That seems to help get things going quicker. I find hardwood kindling helps too.
  12. RichE23ACR
    RichE23ACR
    Hunterdon, NJ
    Thank you, all! I did not think I was missing out here, have long realized that there is always more to learn.
    When I tried a top-down fire, I built upside-down. Started with 3 logs, then medium kindling, followed by fine kindling topped by a bit of newspaper.
    Our stove is in the basement, goes out through a former window well, then 24' of triple wall pipe ending higher than the peak of the roof.
    When the stove is cold, it suffers from " stack effect " or cold air flowing down the pipe. Cracking the garage door open a little bit reverses the flow & it's easy to light.
    Now my next dilemma CAD, should I buy another saw ...
  13. buZZsaw BRAD
    No!!! Buy another five. :saw: :makeitrain"
    When I joined FHC in 2019 I had three saws. Now I have over a dozen. They come and go.
  14. brenndatomu
    Open the stove up and give it a blast of warm air with a hair dryer...depending on the stove model, you blow warm air "up the chimney" as best you can...above the baffle, through the bypass, whatever. It works well, just don't point it toward the ashes! :startled: :rofl: :lol:
  15. RichE23ACR
    RichE23ACR
    Hunterdon, NJ
    I've tried that, with limited success, opening the garage door works well.
  16. RichE23ACR
    RichE23ACR
    Hunterdon, NJ
    This crew is a bad influence when it comes to chainsaws! Over the years, I never had more than two. Now, if I count all the saws, it's something like 10. Five of which get used regularly.
  17. metalcuttr
    metalcuttr
    western WA
    These three questions should the first three on the questionnaire for the FHC dating site!:eek: It would solve a lot of problems later on!:D
  18. metalcuttr
    metalcuttr
    western WA
    We could probably add "Elm or No"?
  19. theburtman
    theburtman
    I was just thinking the same thing
  20. BuckeyeFootball
    BuckeyeFootball
    Switched to top down a few years ago and haven't looked back.
