Top and tilt kit, anyone have one?
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Oct 20, 2022.
  1. Screwloose
    Screwloose
    Looking to add top and tilt cylinders to my 3 point. Not wanting any hoses.
    Looking at fit-rite, surplus center ext.
    Any thoughts or recommendations?
  2. Screwloose
    Screwloose
    Well I just looked at Fit Rites website and minimum lead time is 36 weeks !!
  3. MasterMech
    Some hoses are going to be a necessity. I don't think I've ever seen a kit with hardlines.
    Screwloose likes this.
  4. Screwloose
    Screwloose
    Sorry I should have been more clear. I don't want to purchase generic hoses in a kit as I always get custom hoses made. Well that and I'm putting a 4 spool valve in so no supplied hoses would work anyway.
  5. corncob
    corncob
    Somewhere in Lower Michigan
    Never had the need with ag equipment.
  6. Krackle_959
    Krackle_959
    Coastal Maine
    Have a factory top and tilt kit on the 4052R, bought it with the tractor. I use it mostly for making the skidding winch dig in better when the tractor is not perfectly on flat ground. Also comes in handy for grading ditches with a rear blade, and changing the angle of the landscape rake for grading loam.
    A lot of people have the fit-rite setup, and apparently summit hydraulics has gotten popular for valves and kits. I priced it out when I ordered the 4052R and it was cheaper to have the factory install it, than to buy it through fit-rite, and that was in February 2020.
  7. Screwloose
    Screwloose
    I intend to use it much the same way. Fit rite is 3 years out, forget that. I'm only after the cylinders themselves, valving I've got covered.
    Might end up making my own tilt cylinder so it fits properly.
    brenndatomu likes this.
  8. MasterMech
    What, you want them to fit, last more than a year, AND not leak? Jeez...... :loco: :crazy:;)
    brenndatomu and Screwloose like this.
  9. corncob
    corncob
    I think you mean dealer, not factory.
  10. fuelrod
    fuelrod
    Western Maine
    I welded up my own top link for 2 of my tractors and they're very handy for several things. I think I've seen them at surplus center but their pretty generic in length and stroke. I've never needed a tilt feature, that might be the tough one to build.
    eatonpcat likes this.
  11. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I added a 4 spool rear on the Kubota and a single spool on the ford. I use an off the shelf cylinder for top. I think from surplus’s center.
    Worth its weight in gold on all the rear implements.
    I haven’t needed tilt ever so never messed with that.
  12. corncob
    corncob
    One thing I've never had to do is add any 'spools'. Both my M9's came with 6 outlets and the top one is flow control for orbital powered implements. I use them all on occasion too. Better (and cheaper) to spec them with the maximum number of outlets when buying them.
    MasterMech, Screwloose and JD Guy like this.
  13. Nixon
    Nixon
    West Sunbury,Pa .
    Had the Kub. Dealer install top and tilt when I bought the tractor . As stated above , comes in handy . It also allows me to run my stump grinder’s hydraulic cylinders .
