Took a chance
Discussion in 'Chainsaws and Power Equipment' started by Erik B, Jun 28, 2018.
  1. Erik B
    Erik B
    Western Wisconsin
    At times I am a bit gunshy when it comes to working on a piece of equipment. I sheared off the bolt holding the wedge on to the ram. BTDT This time when I got the broken bolt out the holes in the ram weren't lining up with the holes on the wedge, the ram seemed to have turned a bit. Not having much experience with working on hydraulics I was leery of trying to spin the ram. Spinning the ram was the only way line up the holes for the bolt. I stuck a rod thru the hole on the ram and gave it a little spin, just enough to allow me to put in the new bolt. If there are others here with limited working knowledge of hydraulics, knowing something like it being OK to spin the ram to allow for alignment of holes may come in handy.
    Eric VW, Chvymn99, RCBS and 4 others like this.
  2. Hammy
    Hammy
    New Brunswick
    LongShot, Eric VW, Camber and 4 others like this.
  3. brenndatomu
    Yup, won't hurt a thing
    OldJack, Eric VW, Camber and 6 others like this.
  4. bocefus78
    bocefus78
    Indiana
    X3
    You did just fine. Leverage has been used to fix many millions of pieces of equipment. Congrats on the diy. Makes ya feel all good inside, doesn't it?
    LongShot, OldJack, Eric VW and 7 others like this.
  5. Erik B
    Erik B
    Western Wisconsin
    I didn't know if I would mess up any seals in it or not and I wasn't in a position to stop and do a lot of research. It was hot out today and I wanted to finish what I had started.
    Thanks for the reassurance.
    Duane(Pa), Eric VW, Chvymn99 and 5 others like this.
  6. Horkn
    The seals should be round, just like the rod.;)
    All good:)
    OldJack, Chaz, Eric VW and 4 others like this.
  7. amateur cutter
    Nice job! Cylinders aren't real complex mechs. You did good!
    Chaz, Eric VW, Chvymn99 and 5 others like this.
  8. nsmaple
    nsmaple
    Nova Scotia Boonies
    Do you know why the bolt broke? It shouldn't see a whole lot of stress if things are designed & working normally - mainly should just be bringing the wedge back with the ram when retracting. Unless the wedge is binding on the beam a bit or something like that. Or I suppose getting it jammed in a split really bad then trying to unjam it by backing it up against stops.
    Eric VW, Chvymn99, Hammy and 2 others like this.
  9. brenndatomu
    Kinda what I thought too...but I've heard of a bunch of people breaking them lately...
  10. Erik B
    Erik B
    Western Wisconsin
    I usually break one every few years. It maybe nothing more than fatigue. The bolt usually breaks right by the beginning of the threads. I would like to find a 4 inch long hardened bolt, 1/2 inch thick with a 3/4 head with only about 3/4inch of thread instead of the inch and a quarter I am using now.
    Hammy and Eric VW like this.
  11. brenndatomu
    Just buy a longer bolt and cut the threads off you don't want
    Hammy, OldJack and Camber like this.
  12. Erik B
    Erik B
    Western Wisconsin
    Has anyone used a piece of steel rod in place of a bolt to hold the wedge onto the ram? In my mind, you would need an appropriate length of rod with a hole thru it on each end to accomodate a cotter pin. Maybe I am out of my mind:hair:
    Hammy likes this.
  13. OldJack
    OldJack
    Saskatchewan, Canada
    Most steel rod isn't as strong as a bolt. What you want is a higher strength Grade 5 or 8 bolt. An ordinary Grade 2 bolt has a plain head, a Grade 5 has 3 "spokes" on the head and a Grade 8 has 6 "spokes". See this page.
    McMaster-Carr This link isn't taking me to the right place. You might find marked heads if you click around a bit.
    Pull strength for 1/2"bolts, Grade 2 - 5,840 lb.
    Grade 5 - 9,050 lb
    Grade 8 - 12,750 lb
    Grade 9 - Overkill
    Try a truck or farm machinery dealer if you can't get good bolts at a hardware store.
  14. Carbine
    Carbine
    That's what I did on mine. Someone had a bolt (a little long), and would occasionally catch on the wood being split. I put a steel rod in it, and welded a flat washer on each side. If I need to remove it, I figure I can grind it as fast as I could have taken it off with a ratchet lol.
  15. JustWood
    JustWood Guest
    Replace it with the same grade bolt.
    It's designed that way so the bolt shears/wears instead of the ram end or the wedge plate wearing or cracking . Bolts are cheap . Keep a spare around. If you're shearing them frequently then something else is off in the linkage.
    OldJack, Chaz, Hammy and 2 others like this.
  16. nsmaple
    nsmaple
    Nova Scotia Boonies
    There are also some really chintzy quality bolts being sold everywhere these days.
    OldJack, Hammy and brenndatomu like this.
  17. Erik B
    Erik B
    Western Wisconsin
    Those I am trying to avoid. I try to only go to the sources I trust.
    brenndatomu likes this.
