Tomato Plant Help
Discussion in 'Everything Else (off topic)' started by eatonpcat, Aug 9, 2017.
  1. eatonpcat
    Any gardeners out there that can tell me how to fix my tomato problem....
    Thanks for any and all assistance!
    Chvymn99 and Thor like this.
  2. Erik B
    Erik B
    Western Wisconsin
    Looks like blossom end rot. You need to give you plants more calcium, I believe. Egg shells work good. It may be to late for this year but it is worth a try.
  3. eatonpcat
    Thanks Erik B first year in containers and it is not going well!
  4. thewoodlands
    thewoodlands
  5. eatonpcat
    Thanks Zap, glad your back on FHC!
  6. thewoodlands
    thewoodlands
    Thanks, it's been a horrible year for the garden because of the lack of sun so when we finally had some red tomatoes the blossom rot started to form, that's when I did the lime slurry and the spraying with hydrogen peroxide mixed with water.
    I had some of this hanging around that I made the lime slurry out of.
    I sent you the info via conversation.
  7. thewoodlands
    thewoodlands
  8. Scotty Overkill
    Wrap a piece of copper wire loosely around the stalk when the tomatoes start to form....stripped romex wiring works best.
    I heard this helps with several different tomato ailments....
  9. billb3
    Were the blossom ends black from the day the fruit set ?
    That looks more like one of the blights to me. Especially with spots on the sides. How do the leaves look ?
  10. Firebroad
    Firebroad
    Finksburg, Maryland
    +1 for the lime/calcium. eatonpcat , container 'maters are REALLY susceptible to end rot. Make sure you give them a nice even watering, without drowning them.
    Backwoods Savage and eatonpcat like this.
  11. eatonpcat
    Thanks, never heard of this, but willing to give it a try!
  12. eatonpcat
    The ends on the green tomatoes are not black. The spot on the side appears to be a worm or insect hole, but I see no worms. The leaves appear to be normal. Thanks billb3!
  13. eatonpcat
    We may be at fault on the overwatering/drowning and are backing off the water. Thanks Firebroad !
    Backwoods Savage and Firebroad like this.
  14. lukem
    I'd back them off on the water to the point where they start to look a little droopy, them water them just enough to make the soil damp. If you have a bunch of water coming out of the bottom of the pot you've watered them too much.
  15. eatonpcat
    Thanks...Guilty as charged on the overwatering!
  16. will711
    will711
    Pocono Mts.
    All good advice from everyone :thumbs:
    My 2 cents we stop at the farm on the way home and buy them fresh and perfect from them :whistle:
    Didn't bother with growing any this year .
    JustWood, Chvymn99, milleo and 3 others like this.
  17. eatonpcat
    Best idea yet!!
    Backwoods Savage and will711 like this.
  18. lukem
    I picked 20 lbs of tomatoes today. Best I've ever had. I hilled them and put down black plastic...kept them high and dry.
  19. will711
    will711
    Pocono Mts.
    Less work and more time for Smoothies :cheers:
  20. eatonpcat
    About an hour till cap off here!!
