To burn or not to burn?
Discussion in 'The Wood Pile' started by mj_deere, Jan 8, 2015.
  1. mj_deere
    mj_deere
    Western Ia
    :faint:Ok fellas this is going to sound strange coming from a woodburning guy. I have a Us stove company unit. I was tending the fire and was reading the riveted tag on the stove and its says it is a duel fuel unit. Wood and coal. It just so happens I have a pile of coal. My father has always burned wood and has passed that obsession on to me.
    Has anyone ever burned any coal and how do you do it. The reason : Is it worth using this stuff up or should a person just get rid of it. I've used it to do metal work in the forge but never for heat. What do you guys think.
    Horkn, wildwest and Backwoods Savage like this.
  2. tigeroak
    tigeroak
    kansas illinois
    I have a U.S stove to and went and checked mine and I would try a small chunk . If it works mix a little with wood and use it up.
  3. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    When I was a kid there were a few times that Grizzly's Paw would burn coal, but I was way too little to know how it worked. Maybe he can explain.
  4. mj_deere
    mj_deere
    Western Ia
    I pulled my book out and looked about a bit. Was able to find a little about how to load the stove. What scares me is the book says it can creat gases that can explode. Im not real keen on that.
    wildwest likes this.
  5. Grizzly Adam
    Grizzly Adam null
    Algona, Iowa
    Don't we all?
  6. MightyWhitey
    MightyWhitey
    Ever heard of "back puffing"???
  7. mj_deere
    mj_deere
    Western Ia
    Nope. What that?
    Horkn and wildwest like this.
  8. Backwoods Savage
    MJ, many, many moons ago my parents had a stove that we could burn either wood or coal. Most times we burned wood but usually went through about a ton of coal every winter. We would not use the coal until the weather turned, well, about like this week has been. What we would do would be to line the bottom of the stove with coal and fill the rest with wood. We never had a problem with it but I didn't like it because I had the task of breaking up the large chunks with a sledge hammer. Danged dirty job it was. In addition, whenever we burned coal, all the snow around the house would turn sort of blackish.
    As for creating gasses, I would not worry about that and never remember a problem with ours or the neighbors. I remember one of our neighbors would go through about 6 ton of coal every winter.
    The nice part about burning coal is that it will hold a fire a lot longer then wood. Good luck.
  9. wildwest
    Wyoming high plains
    We burned coal in our old smoke dragon. 75% wood, but would put coal on the hot logs/wood coals bed before bedtime. Gave nice constant heat all night and would relight more logs in the morning by itself. I should add the smoke dragon door did not have gaskets (by design) so I didn't worry about gasses building up. I think a bag of coal was 300lbs, we went through several bags every winter.
    It did not turn the snow black around our house, but as our neighborhood changed and new (against burning) neighbors moved in, they complained of the smell. (even though the we were all on several acre plots......)
    Horkn, splitoak, milleo and 2 others like this.
  10. Grizzly's Paw
    Grizzly's Paw
    Lakota, Iowa
    used to burn coal when i could find it it burns good and hot for sure but it last a long time
  11. getstumped
    getstumped
    Nebraska
    Mj, be interested to know what you do. Be sure to let us know what works. If all else, I'll come up there and help solo some more wood for the coming months/years!
  12. fox9988
    fox9988
    NW Arkansas 72717
    I would try it, cautiously at first and working my load size up over trials.
    I was about 6 when my last family member stopped burning coal. I don't remember much about it, it was never burned in our house.
  13. red oak
    red oak
    My FIL burns coal and wood. He burns about a ton of coal each winter I think. He does pretty much what BWS suggests, lines the bottom of the stove with coal and fills the rest with wood. The biggest thing that I've learned with coal is that a little bit goes a long way. Too often I've been at his house and I've put too much coal in and we've been opening the windows later. Coal burns very hot and lasts a long time so if I had any I would use it overnight.
  14. bogydave
    grew up burning coal
    never had any problems of explosions.
    burns dirtier than wood, but burns hotter
    lot of BTUs
    Regulate the air just like you do with wood
    nothing to be afraid of.
    try some :)
  15. wildwest
    Wyoming high plains
    Flip side, being able to open the windows instead of bundling up because its so cold inside is a luxury IMHO :)
  16. UncleJoe
    UncleJoe
    SC Pa
    We had a coal furnace until 1972 when hurricane Agnus flooded our basement with water. I don't recall ever having an explosion. My dad installed an oil furnace to replace it. We had coal delivered 1 ton at a time. The truck had a long chute that went in through a small window and when the guy raised the bed, the coal went right to the "coal bin" which was about 15" away from the furnace. We had 10-15 metal, 5gal buckets for ash that needed to be carted upstairs where they were then spread out on the stone driveway. Very warm heat and coal was around $20/ton back then.
    Horkn, Backwoods Savage and Loon like this.
  17. My IS heats my home
    My IS heats my home
    Albany, NH
    I wonder if coal would work in an EPA stove or better yet a hybrid.
    Has anyone ever tried it?
    Like mentioned, some folks like to sprinkle coal dust on their
    wood fires for a little help with the overnight burns.
    I know very little about burning with coal, I wouldn't risk it on
    anything newer.
  18. splitoak
    splitoak
    jefferson co wv
    I would also be interested in this
  19. splitoak
    splitoak
    jefferson co wv
    Burn it....and report back:coffee:
  20. red oak
    red oak
    Coal burns significantly hotter than wood, so I've read you can do damage to the stove if you burn coal in a stove not designed for it.
    Also, coal stoves draw the air from underneath, at least my FIL's does. Bit of a different procedure than my wood stove that took me awhile to get.
    Coal produces more ash than wood, not really a problem just thought I'd mention it.
    And, for my FIL, cleaning his chimney is a very dirty job. He's basically covered with the stuff by the time he's done. Very, very different than when I clean my chimney.
    Personally I would only burn coal in a stove designed for it. Just my 2 cents.
