Timberjack Skidder
Discussion in 'Chainsaws and Power Equipment' started by Skier76, Jun 6, 2025.
  1. Skier76
    Skier76
    CT and SoVT
    This showed up at our neighbor’s property in VT late last weekend. Spoke to my neighbor recently and he said they were having some land cleared. He’s not sure when the work will begin.
    Regardless, cool piece of equipment. I want to say this is powered by a Detroit? Hope I’m around when they fire it up! That’ll give me the answer.
  2. Screwloose
    Screwloose
    I love the sound of a screaming Jimmy.
  3. buZZsaw BRAD
    Coll machine! Slip them A $20 and maybe you can drive it! :quad: Post pics if you do!
  4. Screwloose
    Screwloose
    Keep the $20...... ain't nobody around.
  5. Skier76
    Skier76
    CT and SoVT
    There aren’t any keys in it…..and I also didn’t see a place to put keys. Our neighbors house is way up the driveway. My wife texted the wife and she had no idea it was delivered. So yes! An opportunity is there!
    :D
  6. Farmchuck
    Farmchuck
    Nepa
    If I remember correctly turn the battery box on hit the starter button and go. It’s articulated it steers with a lever not a steering wheel.
  7. Skier76
    Skier76
    CT and SoVT
    That sounds about right! I took a look at the operator station and saw a lever for steering, the front blade and winch.
  8. Jeffrey Svoboda
    Jeffrey Svoboda
    Ol 2 stroke diesel. :dex::dex:
  9. Canadian border VT
    This sounds right should be 2 buttons one is a warmer.. old school glow plugs type thing
  10. JimBear
    JimBear
    Just go look under it & see if there is an oil puddle, if there is then it’s a Detroit.
  11. JimBear
    JimBear
    I like the way you think.
  12. Skier76
    Skier76
    CT and SoVT
    I shall! I already took a look at where it articulates. There’s a hearty amount of grease, oil and sludge around the u joint.
  13. brenndatomu
    If it does "need" a key to run, a bolt or screwdriver shorted across the starter solenoid terminals will make it crank, after you ziptie the fuel solenoid to "on", if it even has one, it may be just a push/pull cable! But make it crank with the fuel on and you will be rewarded with that distinctive "raaaaawr"! :tractor:
  14. brenndatomu
  15. brenndatomu
    Yup, slobbery ole pigs they are!
    Locally there was a milk hauler that had an old International(?) cab-over with a 671 Detroit in it...when you heard that sound coming early in the morning, you didn't even have to look up to know who it was...
  16. RCBS
    RCBS
    Over here
    50 year old machines still bringing in the wood.
  17. Woodtroll
    Woodtroll
    Mtns of SW VA
    Unmistakable sound! :thumbs::thumbs:
  18. Eric VW
    Sharing ways to hotwire a skidder…..
    :whistle:
    :picard:
    I’d be slipping someone a bill and beers for some skidded wood to my property!!!
  19. brenndatomu
    Hotwire/DIY is more fun...:D
  20. Eggshooterist
    Eggshooterist
    Erff
    I saw a neighbor, probably 40 years ago, pull a house trailer out of another neighbors property with one. Drug it right through the ditch too because you couldn't make the turn and stay in the driveway. It was a spectacle for awhile. Lol
