Thoughts on Short Leg Kit
Discussion in 'Modern EPA Stoves and Fireplaces' started by Lumbering On, Dec 17, 2013.
  1. Lumbering On
    Lumbering On
    Due to clearance issues, my long awaited Jotul Castine will live inside my fireplace.
    The height to the lintel is 31 inches.
    The height of the Castine is 28 1/2 inches, so it will fit.
    With the short leg kit, it is 26 inches tall.
    Question is: Is there an advantage to the shorter height in a fireplace install?
    Does it allow the heat to circulate out of the firebox better?
  2. fox9988
    fox9988
    NW Arkansas 72717
    The long legs will only allow 2 1/2" to attach the liner, not sure that's doable. I'd go for the short legs, more room and better circulation.
  3. Todd
    Todd
    NW WIS
    What are your clearance issues?
  4. fox9988
    fox9988
    NW Arkansas 72717
    Todd just posted a pic of a small fan under the stove pushing cold air to the back and up over the stove. That would help a lot on a FP install with a insulated block off plate.
  5. Lumbering On
    Lumbering On
    front clearance. to make my 16 inches, 3/4 of the stove will be in the firebox.
    I'll look for the thread with the fan
