this weeks tutorial, gluing up an odd joint
Discussion in 'The DIY Room' started by ironpony, Aug 15, 2018.
  1. ironpony
    ironpony
    Mid Ohio
    well thought I would pass along some of the things I have learned over the years. I am currently building a
    shoe lazy susan for the wife for the master bedroom closet. This cabinet will be floor to ceiling and work like your kitchen lazy susan, only it will hold shoes and necklaces. I will try to remember to take and post pics as I go but I will post finished ones, hopefully by weeks end.
    So in the process of doing this I need to glue up a 45 degree angle which can be annoying but there is a simple way. Follow along, after ripping your 22.5 degree cuts you lay the birds out on the bench point to point.
    Next use shipping tape to tape them together.
    After taping flip them over and apply glue
    fold the pieces together and clamp gently
    clean off excess glue and let dry overnight, the next morning you will have a nice tight seam
    MikeyB, Unhdsm, eatonpcat and 12 others like this.
  2. ironpony
    ironpony
    Mid Ohio
    these are the top and bottom of the cabinet the cabinet will be 42x42 along the wall. it is 60 inches on the diagonal and each rowing shelf will be 24x28. It will make more sense as it goes together.
  3. Woodwidow
    Looking forward to more pics.
    Screwloose, Chaz, Eric VW and 4 others like this.
  4. imwiley1
    imwiley1
    Wisconsin
    That is a slick way to glue up that joint. Thanks for sharing and can't wait to see the rest.
  5. Eric VW
  6. brenndatomu
    Good thing there was no rolling involved in making this joint...would have made for an awkward thread title...:whistle: ;) :rofl: :lol:
    Nice tip! :yes:
  7. Eric VW
    Why didn’t you select the :smoke:.......?
  8. brenndatomu
    Was teeing it up for you...;)
  9. Eric VW
    :salute:
    :D
  10. papadave
    Wrap it up in a bow too............. :whistle:
  11. ironpony
    ironpony
    Mid Ohio
    Wound up working on some other things yesterday, but made some good progress today.
    started by setting the base and assembled each shelf section in place, it is very deceiving as to how heavy this thing is.
    The cabinet and shelves consist of 6 4x8 sheets with almost no waste.
    the shelf assembly sit on a 12" ball bearing turntable rated for 350 lbs. the top is a simple 3/8 steel rod as a pivot
    Couple of pics, did not take as many as I hoped had to keep concentrated on the shelf assy. level, plumb and square
  12. ironpony
    ironpony
    Mid Ohio
    Each shelf is 24" deep and 28" wide so 12x28 on each side, Four pairs of the wife's shoes sit on each shelf. On the ends there will be hooks for belts and necklaces, she literally has several hundred necklaces. I had originally planned to have curved ends on the shelves so she would have more shelf space but she decided to go for necklace storage. Next up is the cabinet for storing the iron and ironing board, then the clothing shelves and rods.
    And for those wondering, it is not as much wasted space as it appears. The corner of a closet can only be used from one side so you loose space there anyway. The sq. footage of the shelves is 46.6 sq. ft. total
  13. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    You are very talented!
    eatonpcat and brenndatomu like this.
  14. eatonpcat
    brenndatomu likes this.
  15. ironpony
    ironpony
    Mid Ohio
    UPDATE; a few new pics
    shelves 17" deep
    Ironing board cabinet
    A few shoes and a dog toy
    A "couple of her necklaces
  16. chris
    chris
    SE WI
    It's all about the accessories.:D
    brenndatomu, eatonpcat and papadave like this.
  17. eatonpcat
    Looks great IP!
