  1. The Annual Tradition is Back!!!! It's time for our Annual Firewood Hoarders Club Secret Santa Gift Exchange! Deadline is: Sign Up will be closed on Saturday November 9th at Midnight (central time) Official FHC 2024 Secret Santa Gift Exchange
This is what a cord looks like
Discussion in 'The Wood Pile' started by Rickyblazin, Oct 6, 2024.
  1. Rickyblazin
    Rickyblazin
    Pottstown PA
    This is what a cord looks like in rounds…roughly stacked 4 ft high 24 ft long and 16 inch wide…we cut twice the amount in the same time when working with bigger logs…jbsawman gathered some old logs so we could cut a cord for a mutual friend
    JDU, Cash Larue, FTG-05 and 19 others like this.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Id be curious as to what it stacks up to once split.
  3. SD Steve
    SD Steve
    South Dakota
    Right!???!! Take out that empty space in between the rounds!
    eatonpcat, Horkn, metalcuttr and 4 others like this.
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    I'm thinking it'll stack out to a good bit more than a cord once split. Even if he's a good, tight stacker.
    Once a round is split, even just in half, its never the same size again. They always grow if split.
  5. stoveliker
    stoveliker
    Eastern Long Island
    On the other hand, more spaces (because more pieces) even if they are smaller.
    It'll depend on whether the grain is straight; if twisted you'll end up with more air between the splits. If not, flat against flat will decrease the empty space.
  6. Highbeam
    Highbeam
    It's like crushing rocks, more pieces makes the pile smaller.
    Nobody knows if that is a cord until is is split and stacked.
    JB Sawman, brenndatomu, Bill2 and 6 others like this.
  7. Jeffrey Svoboda
    Jeffrey Svoboda
    I'm not sure that analogy works here.
    Take one round and build a tight box around it. Now split that round into burnable sized peices and try to fit them back into the box.
    Volume increases once split.
  8. Haftacut
    Haftacut
    Rives Junction, MI
    Spot on! We’ve tested the theory here before. Not sure where the thread is, but definitely been tested. Big part of why I hauled in rounds instead of splits when I removed a fencerow a couple years ago. Fewer trips for sure
  9. MikeInMa
    To a point... a chipper makes smaller pieces from large.
  10. Jeffrey Svoboda
    Jeffrey Svoboda
    I'm sure that's where that analogy can be used. Thanks for pointing that out. :salute:
  11. stoveliker
    stoveliker
    Eastern Long Island
    But this will also depend on the size of the box,given the wasted space at the edges.
    JB Sawman, eatonpcat and MikeInMa like this.
  12. blacktail
    blacktail
    PNW
    Find a round that will just barely fit into a 5 gallon bucket. Then split the round into pieces and try to put them back in the bucket.
  13. billb3
    Like a swedish torch ?
    JB Sawman and eatonpcat like this.
  14. stoveliker
    stoveliker
    Eastern Long Island
    My point is that a bucket experiment is a poor reflection of a cord experiment; all edges have air/wasted space because the bucket imposes how the splits go. A stacked cord has only such limitations at its outer edges.
    JB Sawman likes this.
  15. Elm-er Fudd
    Elm-er Fudd
    Kansas
    I can tell you that I can load a heaping load of rounds, loose thrown into my dump trailer. Then dump them out and split them and throw the splits back in the trailer. The splits won’t fit. Have done it several times and always end up with a small pile of splits that won’t fit back on the load.
  16. JB Sawman
    JB Sawman
    pennsylvania
    Well I had some time and got the splitting done to fill the truck with a cord the truck bed is 10ft x7'6"and the sides are 20inches I did go above the sides a little so it is a good cord the second picture is all that is left of the pile that we (Rickyblazin) and I cut on sunday there was not much left the truck is stacked JB DSCF2244.JPG
    Rickyblazin, blacktail, RCBS and 8 others like this.
